Results 11 to 20 of 26
Thread: Unified Base RR Complete Skin Request
  1. #11
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by UK_MP3Car
    BMVEE the ability to switch between day/night skins is possible from a button on the main menu, it just needs the .skin file editing, will look up the command and edit the post here.
    In exectbl.ini create a newfunction:
    i.e:
    "DAYNIGHT","DAYNIGHTSKIN||GAMMA"
    then in the menu.skin place the DAYNIGHT where the GAMMA was, haven't tested but should work
    Thanks... I'll give it a try
  2. #12
    Raw Wave
    Jun 2004
    On the beach
    Quote Originally Posted by Chita79
    It would be so nice to somehow get RR Config on there... also, we should prepare for the picture viewer feature as well!
    Another thing is maybe getting a Network screen for Wifi/BT/cell provider, and being able to connect and disconnect thru dialup (cellphone provider), waddya think?
    I've tried looking for some code to do wifi detection etc but failed so far, I'd love to be able to do a screen for wifi connections. Dialup is easy, I already have a program to display in my skin whether my mobile is connected via GPRS or not and a button to toggle between connected or not.
  3. #13
    Mar 2005
    Maybe Cirond's WINC would embed
  4. #14
    Raw Wave
    Jun 2004
    On the beach
    Quote Originally Posted by BMVEE
    We all need to meet somewhere central (you know... like Iceland... or the North Pole ) go to a pub and hash it all out... I knew that this was going to be a big request. Maybe we should start an implementation request like Guino did for RR.... Guino might also illuminate the stuff we are missing since we can't seem to keep pace with his development.
    Before this goes too far down the path... Unless you disagree, It might be an idea to keep the functions of this skin narrowed to the primary functions... I don't know what the best way to determine what those functions should be (especially since I'll only be able to assist with imput like this). I guess we need to find a starting point and the person best suited to make that decision is a skinner or Guino (IMHO).
    Skinning for RR will become easier for it when we arrive at RR 100% per Guino. It seems like we are nearly there now.
    Most functions coming soon will be as plugins only to RR which will mean the main program will stay the same, the biggest problem I think is everyone has different ideas and needs.
  5. #15
    Mar 2005
    Human nature is to never be satisfied with what you have. to quote some well sung Lyrics... It's not getting what you want, it's wanting what you've got!
    I'm about to go soak up some sun in the vert and squint while looking at my Lilli (I'm so shy).
  6. #16
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    ukmp3car... could u post a snapshot of your gprs skin? i would really like to know how u did that! thanks
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  7. #17
    Raw Wave
    Jun 2004
    On the beach
    Its simply a bit of code that checks for a current dialup connection that makes a label appear in RR thru the RR SDK. The button simply does a sendkey back to the application.
    Will post a pic asap
  8. #18
    Oct 2004
    San Diego, CA
    i would like to be able to connect/disconnect from my sprint vision data service (US CDMA cell provider)
  9. #19
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    I would like to see the wifi status in some kind of RR window. I don't know if it's possible but sometimes it might be usefull.
    in Skin Commands.txt you can find a lot of information and all available options which you might put in a skin.
  10. #20
    Raw Wave
    Jun 2004
    On the beach
    Yeah I know about the skin commands.txt but some of it is still mind boggling!
    I'm going to have a look at MSDN to see if there is anything relating to the XP Wifi Status.
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 01:51 AM
  2. Color-coded skin with MM & RR
    By ruairi in forum MM Skins
    Last Post: 11-05-2006, 03:06 AM
  3. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 07:48 PM
  4. HELP!! RR can't find skin
    By Bullwinkle777 in forum Road Runner
    Last Post: 03-27-2005, 12:59 AM
  5. request: skin browser?
    By Asian Gang Lord in forum MediaCar
    Last Post: 11-17-2003, 01:50 AM
