Results 1 to 7 of 7
Thread: Spacebar as sendkey
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Spacebar as sendkey
    Hi all,
    I have a little problem with sending a sendkey command to Routis.
    When I launch GPS and the Lady gives me directions, I can hit the Spacebar and she will repeat it. Now I am switching back to my main menu where I have a Button what says Directions. I would like to send that spacebar command to Routis, but when i click that button nothing happens. If I hit the Spacebar she repeats it. I have that on my button. "SENDKEY;{SPACE}" but it don't work.
    Thanks for helping
    Manny
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    have your tried.. { } as space ?
    Registered User
    RR can only perform sendkeys on an application if its in focus, my guess is that when you switch to the main menu routis is no longer in focus so the sendkeys dont work.
    Super Moderator xBrady's Avatar
    USA
    I'm pretty sure that sendkey can't send the spacebar command. I still don't understand it all but when using sendkey I could never get it to send the spacebar command. I tried, {space}, { }, " " and anything else I could find online. Just using { } or " " I could get it to send a space (would add a space into a text editor or something) but I couldn't get it to register as being the spacebar for some reason. I wasn't doing it through RR, just my own program but it uses the same sendkey.
    Installed.
    -GPSSecure- - GPS Tracking
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    After I launch my GPS Software and go back to the main menu I CAN hit the spacebar and it repeats the last maneuver even when the map is not shown. That tells me that it is working. I will try any other command to send to the GPS and see if it is the Spacebar command.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Smile Working!!!
    Just for you guy's who would like to know. I figured it out in RR and Sendkey Commands. I launch RR, hit to GPS and the back to my Main Menu.
    Under the button command I put "SENDKEY,{ }". Now when I hit the middle of my menu (The Car) then iGuidance will repeat the last maneuver. Works like a charm.
    Thanks CdRsKuLL
    Jan 2004
    When I use sendkeys in VB, I have no problem sending a " ".
  1. SENDKEY and SPACE key
    By ruairi in forum RR Bug Tracker
    Last Post: 04-11-2005, 09:32 PM
  2. SENDKEY & MM Embedding
    By ruairi in forum Road Runner
    Last Post: 04-04-2005, 05:36 PM
