I implemented auto switching for my reverse camera using a cheese
video box. It converts the NTSC video from the rear camera to VGA. There is a small on/off button switch on the box that switches inputs between the VGA passthrough input and the NTSC input. All I had to do was solder a wire to the switch pads and hook a relay up between that and my reverse light. Whenever I put the car in reverseit instantly switches to the reverse view.
This has the advantage that it will work with any VGA screen, not just the lilliput.. It also uses a 640x480 signal, so if you run 640x480 desktop there will not be any mode switching going on either which can be nice since the xenarc and lilliput both sometimes have sync problems when switching between resolutions.
mauri: Have you considered building a backlight dimmer circuit that takes the illumination wire in the dash as an input so that you can dim the LCD with the dash illumination? I have been wanting that feature for a long time, but there weren't many electronics folks around here
I understand that to get backlight dimming either the input or the output of the CCFL's inverter needs to be modulated with PWM.. So the circuit should be designed to do something like this:
Illum wire @ 0V (headlights/dash illum off/daytime) -> 100% duty cycle
Illum wire @ ~12V (headlights on/dash illum full/night) -> 40-80% duty cycle
Illum wire @ 3-4V (
lights on/dash illum min/night) -> 30-40% duty cycle
I imagine these voltage ranges will be different between cars and I also imagine that the duty cycles will be different between LCD monitors and inverters.. So it would be good if they could be slightly adjusted with a little screw potentiometer or something. If you have the time to design a circuit like this, I know a lot of people would be interested
