Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: Update my first hardware (Serial Voltmeter).Add two new functions
  1. #41
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Same old story,Nothing worth having ever came easy! i've been looking for this function for ages,now its come along i'm not skilled enough to impliment it,BUMMER.I might have to start skipping your threads Mauri,to keep from depressing myself.
  2. #42
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Marui.... heresa thought... if all you are doing is sending pulses or briefly connecting the curcuit to move from AV and VGA then I guess if youb can change the number of pulses and timing it may be possible to adapt to other screens.
    Further more if you say its RR compatible then you could just use this as a sensor and let RR switch inputs ( ie USB cam 1 or 2 ( if you have forward for pasengers and reverse ) or Svid / compersite of a TV card using the Winamp plugin ) - also allowing another genric use.
    In fact the above may work with a simpler circuit I guess.
    Lastly - can any one build these in the UK ?
    Terran
  3. #43
    Jan 2003
    All - a UK supplier is trying to gage intrest here ( http://www.digital-car.co.uk/forum/s...ead.php?t=3363 ) - If there are enough to bring the cost down he may get a batch run off.
    @Mauri - I don't belive he will make money on the design only the building of... which seems fair enough although if poss can you attach the PIC software ( for the chip not to load it ) on this thread ?
    Terran
  4. #44
    Jun 2002
    Malaysia
    Mauri,
    From your first post, you said on CN4, switches 1 & 2 connects to Switch Lilliput. What do you mean by this? Is this the A/V switch on the button board?
    Where does switches 3 & 4 connect to? You said Pin 8 and Pin 12 on the Lilliput. Where is pin 8 and pin 12 on the lilliput?
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. Replies: 22
    Last Post: 03-04-2006, 08:35 PM
  3. serial ata hardware consumption
    By kilomo in forum General Hardware Discussion
    Last Post: 03-15-2005, 01:53 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-13-2004, 11:29 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
