+ Reply to Thread
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: Update my first hardware (Serial Voltmeter).Add two new functions
    FLAC mauri's Avatar
    Jan 2004
    Four functions with a one hardware:
    Serial Voltmeter (see my old thread )On-line for download my hardware for RR (Serial Voltmeter) implemented by Guino
    Timer for power GPS when the PC and out
    Automatic switch VGA-AV and AV-VGA with input from the lamp reverse of the car(only for Lilliput) connect in parallel to the switch original for rear cam use
    Automatic fixed lighting of the blue leds of the keys when the lights of the car(only for Lilliput) connect to the pin 8 and 12 of the Lilliput
    In the future I put in download the material for to build "home made" this hardware
    In enclosure the photo of the new hardware
    Mauri
    01/05/05
    UPDATE PHOTO NEW VERSION OF THE HARDWARE
    Edit: ALL the Input -Output in the new board is optoisolated.
    For all guys:
    If you have the Lilliput monitor (7" TS) I ask you to make a test:
    Turn on the PC and also the Lilliput, tries to push the button AV to manually go to AV1 (the PC has to be in initial phase of boot) and tell me if Suffered the Lilli, only in this condition (first 5/8 second max of operation) succeeds in commuting from VGA in AV1 or no.
    Do you him to know in this thread.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I assume the AV/VGA Lilliput switching can get out of sync if you swap the modes externally via the button and/or remote, right?
    FLAC mauri's Avatar
    Jan 2004
    The Pic simulates the input on the original button of switch of the lilliput VGA-AV.
    Mauri
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I am sorry but I didn't get it. Will this device switch the VGA to AV1 and 2 on a lilliput automatically hen the reverse light is on and then back to VGA when it is off?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Zebelkhan
    YES!
    default VGA
    turn the revers light
    switch VGA-AV1
    off revers ligth
    switch AV2-VGA
    Mauri
    Dec 2004
    Bay Area, CA
    Cool...I am off reading your original thread. Hope you have info on how to build or buy over there....
    FLAC mauri's Avatar
    Jan 2004
    I have built" home made" ALL....
    The old version is in download in my web space (see the link) by now for a while, full version, and compatible to 100% with RR (thanks Guino)
    Also the new version and perfectly already it works (tested).
    I use this rear Cam,waterprof, in enclosure the photo
    Mauri
    Dec 2004
    Bay Area, CA
    I read the other threads and downloaded the project. Unfortunately it is way over my head. Will you build and and sell one to me? I only need it to switch the lilliput. Thanks.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    are you selling these built. I may be interested
    FLAC mauri's Avatar
    Jan 2004
    NO,I don't sell this.
    My idea and for everybody, free, to build him "Home made"
    Mauri
+ Reply to Thread
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Replies: 22
    Last Post: 03-04-2006, 09:35 PM
  3. serial ata hardware consumption
    By kilomo in forum General Hardware Discussion
    Last Post: 03-15-2005, 02:53 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
