Results 1 to 10 of 12
Thread: Application Embedding
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I tried to make a button on the menu.skin embed an application but only half the times it would work properly.. Sometimes RR minimizes!! It is like something happening with the timers maybe?
    I finally enabled embed support in base plugin but still the same thing!
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    I am also trying to embed something in it. I want to embed IM clients such as aim. I have it mostly working but I get that same problem as you were it minimizes.
    can anyone help us out?
    thanks
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    please post the button commands you're using. Then I can try to help.
    @DJBac
    If you're tryihng to embed your plugin, you MUST use the PLUGIN Command and NOT the load OR run commands.
    Ride Runner RR's Myspace
    Jun 2004
    GREECE/Athens
    I am trying to embed an application in RR.. I also tried to embed the same app in my plugin!!
    Here is the button command
    B01,142,258,066,084,"LOAD;ACCEL.SKIN;accelarometer ;D:\Base Plugin\accelerometer.exe;accelerometer"
    I have set in the accel.skin where it should embed... It embeds fine but not always!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what happens when it doesn't embed ? does this application, by any chance, change the window title depending on what you open/run ? I can only assume it's something with the window title you're using..
    Also, I see you're running this "application" from your base plugin folder -- if this is a plugin, you MUST use the "PLUGIN" Command (as I said before).
    Jun 2004
    GREECE/Athens
    The application I am trying to embed in the plugin is not another plugin.. It is just a VB app that doesn't change window title!!
    it seems to embed but RR (or plugin) minimizes.. If I close the embeded app and then try to open it (more than 20 times) it embeds fine!! Only the first time is the difficult one!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you need to make sure you don't have any other application with the title "accelerometer" (or similar) running or RR may be trying to embed the wrong window.. you can probably try changing the applications title to something more specific..
    Jun 2004
    GREECE/Athens
    Tried to change it to G Meter.. Exactly the same reaction..
    When I try to put something different as app title it won't embed it at all..
    I cannot figure out anything else!
    Should I put something else apart from the embed space in the accel.skin?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if you can send or post me the application i can tell you exactly what to use for window title OR you can look at the FAQ on embedding applications, using the WinSpectosSPY application.
    Jun 2004
    GREECE/Athens
    I've tried winspectosSpy app and read the FAQ!!
    The app is attached!! It is just a temp one!
    Attached Files Attached Files
  1. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 09:25 AM
  2. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  3. How to embbed any Application in RR ?
    Last Post: 03-20-2005, 01:35 PM
  4. embedded GPS application problem
    By Bokky in forum Centrafuse
    Last Post: 01-23-2005, 01:44 PM
  5. Embedding a backup application
    By l0gic in forum MediaCar
    Last Post: 10-22-2004, 05:55 AM
