Results 1 to 10 of 10
Thread: Issue with the radio?
    Low Bitrate l0gic's Avatar
    Essex - UK
    Hi,
    probably me being a dub ***, but just in case.....
    Using RR in shutdown mode,
    if I am playing the radio (DLink direct - no radiator) and shutdown,
    on start up RR drops into playing the mp3 playlist rather than going back to the radio.
    Is this normal behavior or is this sometihng I can configure.
    I've looked around the configuration and I have .
    I notice there is a radio issue ongoing at the moment but I'm not sure if it would be related.
    I do have the rr.exe fix for the missing playlist problem installed -I assume it is the same as the one suggested for use with the radio issue.
    cheers
    Kevin
    Build status {..........|} 99%
    All installed - now into the fiddling about stage
    Car:MR2
    MB: EPIA C800
    Display:Xenarc 700TS
    Power:PW-70A & ITPS
    Mem:384MB
    HDD:40Gb Maxtor Diamond max
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    are you shutting down (Power OFF) or using Hibernate ? The radio resume offered for FM and XM only works while moving around within RR or when using Hibernate. PowerOFF, Restart and Exit always resumes to music (MP3), because there chances of resuming to "static" since you may have moved the computer/car etc...
    Ride Runner RR's Myspace
    Essex - UK
    Hi Guino,
    yup - I'm using power off / power on.
    So it's a design feature then. That explains why I couldn't get it to work
    Is it possible to make this an option in the config?
    The PC is in my wifes car.... and she mostly listens to the local radio rather than albums.
    As the car/PC is likely to be in the same place when being stopped and started the same radio station is likely to still be available - just like a standard car radio scenario.
    thanks
    Kevin
    Car:MR2
    MB: EPIA C800
    Power:PW-70A & ITPS
    Mem:384MB
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    you could add RADIO as a command on RRConfig to make it go to radio always when it starts... at least a temp fix so she calms down....
    put "RADIO" (or whatever your radio skin command is) in "Start command to execute" on the very first ootions in RRConfig... this will make it always click "RADIO" when RR starts....
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That is exactly what I was going to sugest.. you can always start up the radio/xm by adding it to the start command. RoyN beat me to it.
    Essex - UK
    Excellent suggestion guys - I will give it a go, thanks
    I'm not in her good books at the moment, I've ripped out her old system and put in the car PC (brownie points for sat nav & easy interface) but I managed to blow an output on one channel of the amp, plus the whole audio has a background hum (either the knackered amp or, I suspect, the GPS signal running alongside the audio cable)- so I have some work to do to make up for the failed 'delivery experience' - LOL
    thanks for the help
    Kevin
    Car:MR2
    MB: EPIA C800
    Power:PW-70A & ITPS
    Mem:384MB
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    Low Bitrate cyrix^'s Avatar
    Feb 2005
    Denmark
    I have a problem with the radio too.
    When I press the radio button, the program freezes as soon as it enters the radio "menu"..
    Kinda irritating, because I don't want to use the radio function at all, but it happens that you press the wrong button.
    Is there anyway to disable this function ? Or maybe another solution
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you set it to DLink in RRConfig it should not freeze up.. but if you don't use the option you should probably disable it in your menu.skin file just delete or comment out the line that says: BXX,XXX,..."RADIO"...
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    The background hum is prolly your VIA board if you're using onboard sound...The gps signal is not strong enough to mess with your audio.
    Feb 2005
    Denmark
    Quote Originally Posted by guino
    Just set it to DLINK, it works just fine
    thanks
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. Seth's Radio issue
    By EBFoxbat in forum General Hardware Discussion
    Last Post: 09-13-2004, 12:24 AM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 10:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
