Results 1 to 3 of 3
Thread: Set position of popup screens (custom menu)
    Jul 2004
    NL, Druten
    hey there..
    Anyone know if it's possible to set the position of a menu?
    I made a new menu (small eq) and want to load it on top 0,0,800,340 of the screen. right now it appears in the middle of the screen.
    thanxs, Martijn
    Feb 2005
    It's not implemented, but it's a good suggestion for a next version of RR.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can do it with a bit of work already.. You can choose between two options:
    Option 1:
    -Create a Menu which is Full Screen and has the "background" as the calling screen -- as long as you only define the buttons of the menu in the .skin file it should look like the menu is wherever you drew it.
    Option 2:
    -Similar to the above but more realistic: Make Full Size menu images drawing your menu where you'd like it to "show", then use the "CUT" skin definition to cut the areas around the menu you don't want to show. This will have the effect of showing the menu at the location that hasn't been "cut off"..
    There's an example of Option 1 in the Alpine "City-Cruiser" by Hell-Stopper. He shows the exit menu as a popup on the bottom-right corner while the rest of the screen is "darkened" (like the windows shutdown menu used to be).
    Ride Runner RR's Myspace
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. External gps popup menu
    By Kalt in forum Road Runner
    Last Post: 04-22-2005, 04:06 AM
  3. Any way to set custom resolutions under winXP
    By Mikesz in forum LCD/Display
    Last Post: 01-14-2002, 03:08 PM
