Results 1 to 5 of 5
Thread: Aspect relation video on 16:9 touch screen
    Mar 2005
    Hi, I can,t get working a good aspect relation for my movies, in rrconfig I selected 16:9 option,,,but movies are streched
    Any suggestion??
    Aug 2002
    Eau Claire, Wi
    for dvd i use the nvidia dvd decoder and there is an option to correct aspect ratio in the settings. for divx playback you can try to use ffdshow to adjust the ratio or I use a program called DivXG400 2.8. with these tools basically you can streatch the video overlay vertically.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The issue most of the time is that the DVD itself has black bars on top/bottom that prevent RR from resizing correctly.. you shou try different zoom modes by pressing the "EYE" button.. if that doesn't solve it, then it's time to try some hardware approach..
    Ride Runner RR's Myspace
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Is this what the 848x480 and 800x600 selections are for in the config program? I haven't noticed any difference in the screens I use with either setting. I have a Xenarc 7" which confuses me: it has a physical 16:9 aspect but display is set to 800x600. I never know which to choose in the software to keep the aspect looking right.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RRConfig should be set with the PHYSICAL aspect ratio.. RR will propperly compensate for the resolution you use. The problem is that videos that are NOT propperly cut will play as if any black borders are part of the video -- which will most likely mess up the display. There's a "CUT" zoom mode to try and compensate for that, but it still depends on the video.
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  2. FS: 12.1" touch screen
    By spdfrek in forum Classified Archive
    Last Post: 05-10-2005, 11:30 PM
  3. FS 7" Touchscreen Like Xenarc
    By sebcorazon in forum Classified Archive
    Last Post: 04-06-2005, 01:57 AM
  4. Sharp LM8V31 7.7" touch screen help
    By rx350 in forum LCD/Display
    Last Post: 03-23-2005, 05:25 PM
