Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: FM tuners
    FM tuners
    Can anyone suggest a good FM reciver to use with RR? All the ones I have found are TV/RADIO combos. I can't use an internal PCI one as the case I use doesn't allow one, and USB TVs are rubbish from what I have seen. All I want is a simple USB radio tuner, even if it has to plug into the line-in!
    Just wondering what you guys all use?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Don't know if you've been lurking around the hardware section...but they are working on a radio board, it comming along very nicely...
    Here, just check out this thread...
    HU Quality AM/FM RDS/RBDS Radio with Features
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I'm currently using the D-Link DRU 100 wired into my stock aerial.
    It's OK but it's not amazing.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Aug 2004
    The griffin radioshark is also OK but not amazing. Forget about am but fm comes in, and is listen-able. It seems to be constantly adjusting itself, if it gets fuzzy the software reacts and cleans it up, but it happens quite often so its a bit annoying.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    the d-link is fm only.... I have the hauppauge which is tv/fm and I found tv to be actually useable on some channels in the city in movement! WOW...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    In Europe, I recommend the Cinergy 600.. just finished integrading "direct" support for it including RDS.. Should work well for both TV and Radio.. For elsewhere, it's hard to tell.. Now USB is a hard solution .. there not many good options.. I'll be implementing direct support for the WinTV cards (which supposedly should work with the USB versions).. but I only have the PCI version to try with -- hopefully I'll be working on this later today.
    Ride Runner RR's Myspace
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by guino
    OOOOOhhhhh Goodie... I'm looking forward to playing with this. It'll be nice to have it directly supported.... You are talking the Hauppauge WinTV correct... like the WinTV GO-TVFM???
    FLAC mauri's Avatar
    Jan 2004
    Good, RDS support it's ok
    Only one small problem to PCI card solution:little space to adapt in "carputer solution" the PCI card with the EPIA MB.
    Yes, exist the PCI adapter posted above, but my carputer and systematized all in a small space
    However good thing to implement the RDS in the Cinergy with RR!
    Thanks Guino.
    EDIT:have see my PM for you ?
    Mauri
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @mauri: haven't got anything..
    Here's a prototype for the WinTV... This is just a control application I'll make RR control... I'd like users of WinTVFM (PCI and USB) to report how it works on their system...
    You may have to register the OCX file using:
    regsvr32 hcwWintv.ocx
    The speed of seek/tuning is limited by the Crappy OCX that doesn't seem to ever disable the VIDEO controls while using the radio.
    Let me know..
    Attached Files Attached Files
    São Paulo, Brazil
    I'm going to test this out right now...
    Just a question though, could you consider when you do the TV part, possibly adding a screen for rear-view camera? Basically this screen would be a TV feed on a specific channel (configurable) since the wintv treats the video input as a channel configurable through the interface, and this way we can have a screen that is quicker loading than normal TV, and can be quickly switched to without stopping music or anything...
  1. Which FM tuners are supported?
    By The Grinch in forum Software & Software Development
    Last Post: 06-03-2006, 02:34 PM
  2. Replies: 2
    Last Post: 04-10-2005, 12:18 AM
  3. FM Modulator Question
    By frenchbluefocus in forum Newbie
    Last Post: 11-24-2004, 12:05 PM
  4. TV Tuners/FM Tuners For MCE2005 (Need Opinions)
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 11-05-2004, 03:48 PM
  5. What fm tuners does MC support
    By pugstyle in forum MediaCar
    Last Post: 05-23-2004, 02:56 PM
