Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 61
Thread: RR Interchange - Update RR via a USB Media Stick
  1. #51
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Hey Guys.
    How can I exclude a directory (like the "skins" directory in RR) from being copied to the usb device
    I tried the exclude option but cannot get it to work.
    Any help would be deeply appreciated
    The road is long but we are getting there.
  2. #52
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    tolisn:
    Add this to the line that copies the Road Runner folder to the USB drive: /EXCLUDE:\skins\ that should stop the XCOPY going into ANY folder called skins.
    So the line should look something like:
    xcopy "C:\Program Files\Road Runner\*" "car\RoadRunner\*" /S /D /K /I /Y /EXCLUDE:\skins\
    You may want to change the RR line on your CarPC so it also ignores the skins folder if it is on the USB drive:
    xcopy "car\RoadRunner\*" "C:\Program Files\Road Runner\*" /S /D /K /I /Y /EXCLUDE:.ini+\skins\
  3. #53
    Dec 2003
    Greece
    OK thanks
  4. #54
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Hi all.
    I'm trying to get this working on my PC. I am running into a couple problems with the batch file and I don't know much about how they work. I've tried troubleshooting and changing things around but still can't get it going like it should.
    First problem: Taskkill is not recognized. It pops up errors for the lines saying it doesn't know that command. I got it to keep going once and it went through the RR update.
    Second problem: Keeps saying it can't find the batch label specified. I think this has to do with the Music transfers since the RR update did work one time (but not since then). I would like to be able to add a folder of music to the usb drive, and then when I transfer it, have the autorun take all folders in the Music directory on the USB drive and put them in the Music directory on the carPC. What should the Xcopy line look like for that?
    Third Problem: Every time I insert the usb drive on the carpc, Autorun starts and Windows pops up a message asking what I would like to do with the files (ie: Play them in Win Media Player, Open them in Windows Explorer, etc., or Take No Action). I have to hit cancel every time, even if I hit Take No Action it will still pop up next time. Anyone know a way to get around this and make it stop happening?
    Thanks for any help you guys can give me!!
    Cheers.
    EDIT: Forgot to mention this before, but doesn't RR only update with like 3-4 files? Is it really necessary to copy the whole directory?
    Thanks.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  5. #55
    FLAC edrex's Avatar
    Dec 2004
    If anyone is using the AutoRunUSB program, I got a couple batch files that are working well.
    I have 2 different files, one is autorun.bat (launched when the drives is in my home PC) and autoruncar.bat (launched when in the car). I did this because my computers were having a hard time with the goto Carpc command and it was an easy fix to make 2 files.
    I added a delete command in the autoruncar.bat so that after files had transferred it would then empty the media folders (just music and movies, not the RR files) so that next time I needed to transfer files the drive was "unloaded" and ready.
    Here they are:
    autorun.bat:
    Code:
    ECHO OFF
    REM Road Runner
    xcopy "C:\Program Files\Road Runner\*.*" "G:\car\Road Runner\*.*" /S /D /K /I /Y
    if errorlevel 4 goto lowmemory
    if errorlevel 2 goto abort
    REM Music/Movies Transfer
    xcopy "C:\My Music\To Transfer\*.*" "G:\*.*" /S /D /K /I /Y
    ECHO .
    ECHO .
    ECHO USB Drive is now ready to sync with CarPC!!!
    ECHO .
    goto Finish
    REM -----------------------
    REM WHEN THINGS GO WRONG!!!
    :lowmemory
    echo Insufficient memory to copy files or
    echo invalid drive or command-line syntax.
    goto exit
    :abort
    echo You pressed CTRL+C to end the copy operation.
    :Finish
    ECHO Finished!!!
    ECHO .
    ECHO .
    PAUSE
    exit
    autoruncar.bat:
    Code:
    ECHO OFF
    REM RoadRunner Folder
    xcopy "D:\car\Road Runner\*.*" "C:\Program Files\Road Runner\*.*" /S /D /K /I /Y
    REM Music Folder (Hide display while copying)
    xcopy "D:\music\*.*" "C:\Music\*.*" /S /D /K /I /Y
    REM Movies Folder (Hide display while copying)
    xcopy "D:\movies\*.*" "C:\movies\*.*" /S /D /K /I /Y
    REM Delete Transferred Media
    del D:\movies\*.* /Q /S
    del D:\music\*.* /Q /S
    ECHO .
    ECHO .
    ECHO CarPC is up-to-date!!!
    ECHO .
    "C:\Program Files\Road Runner\RR.exe"
    goto Finish
    :lowmemory
    goto exit
    :abort
    :Finish
    ECHO Finished!!!
    ECHO .
    ECHO .
    exit
    MY PROBLEM:
    The original bat file that Ruari made had TASKKILL commands that would exit the apps being updated (in my case I only need RR closed when I use the carPC). He has XP Pro and I have Home. My XP does not recognize TASKKILL as a command and is not able to close the apps.
    Does anyone know of other commands to use instead that XP Home edition will recognize? Or a list of commands that I can go through and find one that works?
    Thanks.
    ed.
  6. #56
    Aug 2004
    Sydney
    Aparently tskill is available on XP home. give that a try. I cannot confirm though as i have pro on all my XP machines.
    Jas
    Quote Originally Posted by edrex
    MY PROBLEM:
    Thanks.
    ed.
    1994 Toyota Celica
    Epia M-9000, Lilliput 7" LCD, Road Runner/Map Monkey
  7. #57
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by neo_in_aus
    Used tskill /? on a cmd prompt and it came up with a list of switches. Thanks!! I'll try to use that to get the programs closed.
    Cheers.
  8. #58
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Would this program work with something other than RoadRunner? (such as Centrafuse)
    edit:
    Read through the thread and see that people have favored using the posted batch file
    My problem with batch files is that the music copy process isnt advanced enough. I need a copy method that will somehow know what files Ive already transferred to the carputer then only copy new files since the last transfer.
    xcopy can only do it by a static date and robocopy is a little better and can do it by X days old but neither are good enough
  9. #59
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    This program works with any program any folder, hell you can even format your harddrive with it.
  10. #60
    Jun 2003
    Memphis - TN
    Anyone thought of using IOMEGAs activedisk ?
    http://www.iomega-activedisk.com/
    there is a developer SDK.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. USB IR stick to COM port??
    By vxcarpc in forum Input Devices
    Last Post: 03-20-2008, 07:31 PM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Aver Media USB Radio. Anybody tried it out?
    By DrkStormTrooper in forum General Hardware Discussion
    Last Post: 12-28-2004, 04:59 AM
  5. Booting with USB memory stick
    By Fluffy in forum General MP3Car Discussion
    Last Post: 10-01-2003, 06:47 PM
