Results 21 to 30 of 33
Thread: Radio Shark with RR
  1. #21
    Aug 2005
    I created my radioshark skin, and I have everything working the way I want except for one thing. I like the feature of the audioplayer that allows it to play when using GPS, Weather, the Web, etc, and then stops it when selecting Sat, DVD, Video. And when exiting Sat, DVD, Video it automatically starts playing again.
    Now is there a way to set up my new radio button to do this?
    My radio button in my menu.skin is currently set up like this:
    B04,11,186,296,106,"PAUSE||LOAD;Radioshark.skin;tu ner;C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe;radio:","Tune r"
    I also have my DVD, VIDEO, SAT, and MP3 buttons set up so when I select any of them, it will close my radio app.
    So if I am listening to MP3's, then select my radio button, it will PAUSE my MP3's, and start up the radio app. Then I can leave the radio skin with radio still playing, go to GPS, web, etc, and when I select my MP3 button, it will close the radio app, but now I have to press the PLAY button to get MP3 playing where it left off.
    I guess I just wanted the MP3 to start playing right when I pressed the MP3 button.
    I will play around with some more combinations of things.
    Thanks.
  2. #22
    Aug 2005
    Jersey
    what have you guys done to improve radio shark reception cuz mine sucks...
  3. #23
    Low Bitrate ketchup318's Avatar
    Jan 2005
    Monterey Park, CA
    I've tried to do what most everyone did to embed radioshark, but when I switch from radio to my main screen, and then back to radio, it says "radioSHARK already running", I made sure that when i exitted the screen i put "MAIN||CLOSEWINDOW;Radio:".
    What am i doing wrong?
    AMD 1700 & Abit VA-10 w/ 512Mb PC3200 Corsair Ram
    60GB 7200rpm HD - Opus 150W PS - Lilliput 7" TS
    Panasonic Slot DVD - SD Audigy NX 2
    Phoenix Gold 5.1 MT Amp - 2 USB Hubs
    Hauppauge WinTv USB2 - Holux GPS - Belkin Bluetooth
  4. #24
    Aug 2005
    Just an idea, but you could put in the ENTER key, becuase that will actually close radioshark completly.
    But I had it working fine with just the close window command as you have done. Make sure the RadioShark is plugged into your USB port. This might make a difference.
  5. #25
    Aug 2005
    Jersey
    Quote Originally Posted by F350
    how else could you hook it up? other than usb?
  6. #26
    Aug 2005
    Sorry, I meant to say, make sure it is plugged in. I say this because I had my radioshark working great with roadrunner, it would close propelry, and re-open with no problems. Then when I disconnected the radioshark from the PC, and ran RR, I had the same message pop-up (radioshark already running) when I opened the Radioshark skin, closed it, then tried to open it again.
    I haven't gone back and plugged in the radioshark again to see if the message will go away, but I am sure it will since it worked perfectly before.
    I'll try it tonight and let you know how it worked.
  7. #27
    Feb 2005
    When you close the radioshark application, it still runs in the system tray. So when you try and start it again, instead of activating the already running instance, it tells you that you can't start it. I don't know how to make it shut down completely.
  8. #28
    Aug 2005
    I posted this a couple of messages above that my 2 year old figured out that while radioshark is running, you can press ENTER, which will close radioshark completely. It will not run in the system tray.
    Though when I created my skin, I just used the default EXIT command, and for some reason, my radioshark completely closes, and when I go back into it, it starts up again with no problem.
    But just to be safe, I tested it with the ENTER command in my skin, and it works perfect. This is what you need the exit or return button to look like:
    "SENDKEY;{ENTER}||EXIT","Exit"
    This will completely shut down radioshark, and the next time you open it there should not be an error saying it's already running.
  9. #29
    Newbie maiwand's Avatar
    Jul 2005
    Indiana
    Anyone know if there are plans for RadioShark to be implemented into Radiator or know how this could be done? I'm embeddeding the player into RR as a quick fix, but would really like for it to be seamless. Just wondering if anyone has any word on this.
  10. #30
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As far as I know, there has not been any development in Radiator for awhile.. that's one of the reasons I decided to make separate interfaces for WinTV and Cinergy cards... If anybody contacts the manufacturer and they're willing to provide SDK/API information I'd definitely would work on integrating it to RR.
    Ride Runner RR's Myspace
  1. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 10:44 AM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR & Radio Interface
    By BMVEE in forum RR Bug Tracker
    Last Post: 03-20-2005, 01:05 AM
  5. Radio Shark
    By VBWizz in forum Car Audio
    Last Post: 03-12-2005, 07:52 AM
