Results 11 to 20 of 24
Thread: Cinergy radio config in RR Config ?
  1. #11
    Nov 2004
    Bologna
    I Guino, I have the same problem, in RRconfig Cinergy control is grayed.
    I try to uninstall and reinstall all RR, i Update RR with RR updater, i look to c\program files\Roadrunner\cinergy and in the folder i execute register.bat, and i look if there's rrctv.exe
    The file rrctv.exe is in cinergy folder and if execute it function well.
    what did i do wrong?
    Excuseme for my english
  2. #12
    Nov 2004
    Bologna
    P.s. My skin is the original in the RR download i not change it for test
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by sabbio
    try simply editing RR.INI and change the radiomode= line to:
    radiomode=2
    The option in the config is only disabled when the cinergy subfolder is not present.. but there may be a bug on it..
    Ride Runner RR's Myspace
  4. #14
    Nov 2004
    Bologna
    Thank you Guino! very fast in the reply and the problem is solved!!
  5. #15
    Newbie 00roberto00's Avatar
    May 2005
    italy
    hei all!
    ive to do a strange workaraund to put radio working in rr, with the cinergy600.
    before running rr i have to switch on the terratec software panel, put the tv screen and switch to out source (for not having sound from tv)
    then i can start rr and when i switch to radio it works fine with rds and everything.
    but... yes.. there's a but... when in rr i switch back to music or video there's still the radio playing under the other music and i cannot mute the radio only but have to go out of rr and switch back off the terratec panel
    i tried every settings but nothing seems to work.
    got any idea?
    ciao
    roberto
  6. #16
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i have a quick newbie questions on RR with Radio.... is there a way yet to get RDS data on the screen yet? if so, which card would support it? thanks guys
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 00roberto00
    hei all!
    got any idea?
    ciao
    roberto
    have you tried the RRCTV.EXE by itself (outside RR) ? This is basically a modified application I got from Terratec. You should probably mute the line-in while outside RR and have RR unmute it when using radio (Then mute when stop using radio -- setting in RRConfig). I only installed the radio application from terratec, so I don't know anything about the video portion (but it should work with the TV Plugin).
  8. #18
    May 2005
    italy
    hmmm
    I solved partially the problem installing wintv plugin in winamp
    now the tv is showing and running okay, audio and video without other applications to be loaded.
    i still have a problem in the radio skin.
    it shows the frequency, the rds infos but its mute. no sound.
    if i play the same frequency in the TV skin, the sound works (but of course cannot see the rds).
    btw, is there some option/command to force the balance to the middle? (i have an application that when i start it it push the balance to the right, i.e. mapstore michelin)
    Ciao
    Roberto
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's a fix for the michelin maps.. do a search for it.. about the radio, does it start MUTED in RR ? how about if you run it OUTSIDE RR, does it start MUTED then ? I hope you understand you should not be running any other applications than then winamp and RR for this to work..
  10. #20
    May 2005
    italy
    if i run it outside RR, with the original terratec applications for to listen radio i have to switch on the tv application first and then the radio application. it wont start mute but i noticed that the mute switch in terratec radio app is not working.
    when i start radio in RR (no other apps running) the mute button is in normal way and pushing it there's no effect. I checked also in windows mixer if there's some mute button on but there isnt.
    btw, do i have to point to cinergy folder in rrconfig in radiator path? now i left it blank.
    thanks for the michelin thing.. i will do a search
    ciao
  1. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 11:44 AM
  2. Radio Shark with RR
    By pirate_king00 in forum Road Runner
    Last Post: 12-29-2005, 10:16 PM
  3. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. RR & Radio Interface
    By BMVEE in forum RR Bug Tracker
    Last Post: 03-20-2005, 02:05 AM
