Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Cinergy radio config in RR Config ?
    Oct 2004
    Belgium
    Question Cinergy radio config in RR Config ?
    Hi,
    can anybody give me a step by step explanation to configure the Cinergy 600 Radio with RR (so not D-Link or Radiator)
    I've read the FAQ but that does not help me (what should I put in the radiator path, if anything?, ...)
    Thanx
    Pike
    Audi A6
    Via Epia MII1000 512MB / 40GB
    In Dash touchscreen 7"
    Bluetooth / WiFi / GPS / Internet / Radio TV /
    Phone Control / DVD / CD / MP3 / OBD II /
    Internal cam (to watch the kids on the backseat)
    Installing Road Runner FrontEnd now.
    Mar 2005
    Rome
    download the new files for radiator, or run rr updater.
    Mercedes A Class 170 CDI
    Carputer Progress:
    [X---------] 10%
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Radiator is NOT needed. Just select Cinergy on RRConfig, and run register.bat .. nothing else is required. Theres a readme on the cinergy folder as my release post stated..
    Ride Runner RR's Myspace
    Oct 2004
    Belgium
    thanx for the advice
    I did all that (RRUpdater, register.bat) but now i see the Cinergy option is grayed out in RRConfig
    The Terratec radio application works fine
    what did i do wrong?
    Pike
    Audi A6
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The RRCTV.EXE file MUST be in a Cinergy\ subfolder of your RR directory.. it also MUST be the one I posted with the release 5-12 of RR.. if the folder/file is not there, RRConfig will prevent you from choosing that option.
    Oct 2004
    Belgium
    @guino: rrctv.exe is in cinergy directory and is the one posted with the release of 5-12
    I forgot to mention, I use the mmi skin, maybe this has something to do with it ?
    Pike
    Audi A6
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    maybe OT but... I was thinking about purchase this cinergy 600, can someone tell me FOR SURE if the RDS function works even with 3rd part applications like radiator? I'll buy it ONLY for RDS function and I really need radiator AND rds working properly
    EDIT
    for RDS I mean auto tuning when the reception is not precise, I don't care about radio names or other RDS related messages, I only need auto tune
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the skin should not really matter.. but I can't honestly tell if the MMI skin has the radio skin completed for it.. so I'd suggest to try a different skin to rule out that possibility.
    The Cinergy 600 has full control over Radiator .. the change of frequencies is a "hardware" feature if I'm not mistaken (so it should work independent of software). The brushmetal skin has RDS info support, but RDS info will only work with RR's control application (without radiator).
    Oct 2004
    Belgium
    Thumbs up
    Hi again,
    I reinstalled everything from scratch and now it works !!!!!
    I also used the BrushedMetal skin (with Audi logo) as guino suggested because the mmi skin still has some flaws I think.
    During my first install I downloaded the binary distribution and unzipped it manually into the RR directory after the InstallShield.
    The second time I used the update function at the end of the RR install.
    @guino: for RDS support you talk about the RR's control application, is it included in the distribution and if so where is it and how does it work, and if not where can I get it?
    Thanks guino to have continued and extended MediaCar ! It is getting better by the day !
    The only thing I need now is a good TV antenna
    Pike
    Audi A6
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the Cinergy folder is provided in the latest Binary Package on my site (5-12).. you'll need the cinergy folder inside RR's folder and likely need to run "register.bat" in the same folder.
  1. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 11:44 AM
  2. Radio Shark with RR
    By pirate_king00 in forum Road Runner
    Last Post: 12-29-2005, 10:16 PM
  3. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. RR & Radio Interface
    By BMVEE in forum RR Bug Tracker
    Last Post: 03-20-2005, 02:05 AM
