Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Winamp install gets corrupted randomly...
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    hey guys..anyone else here have the problem where the carpc boots up normally, then RR popus up and when you initially try to play an mp3, you get an error window popping up that says winamp has to close. Seems as though my winamp install gets somehow corrupted every so often. The only way to fix this is to either do a system restore (which sux) or reinstall winamp again. I have no idea why this would happen...(btw, im using Winamp 5.05 & RR 5-6-05) Any input would be great! thanks
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    Low Bitrate Henry Winx's Avatar
    May 2003
    Derbyshire/Cirencester UK
    I have a similar problem on 2 separate car pcs, I think it is something to do with music files and how they are encoded, some a friend has done make it happen, mine dont.
    When I come out of standby on some tracks it hangs and I get a winamp error saying it has to close. I have to restart rr and the same track then plays fine...
    EPIA M10000, Kingston 256MB, 40G 2.5" HDD, 40G 3.5" HDD, LG slim CD/DVD,
    Customised Cubid 2699R, Xenarc 7" moulded in dash, Opus 90w, bu-303
    Oct 2004
    San Diego, CA
    with mine, i have to reinstall winamp over again... (or system restore)
    Aug 2004
    Denmark
    Quote Originally Posted by Chita79
    Have the same problem..But isnt winamp only for movies and Mediaplayer for mp3?
    P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by yokeren
    No, not quite...winamp for the music and mediaplayer for videos
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Low Bitrate hakhawk's Avatar
    Apr 2005
    newborough, VIC, AUS
    i have the same problem sometimes, but i have narrowed it down to not shutting down xp properly. so, now i just shutdown properly and it doesnt get corrupted. i am going to go back to winamp 5.02 and try that, because i never remember it happening with that version. it isnt a problem with roadrunner, si i have had it happen on my pc in the house. hope this helps
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sounds like a shutdown/filesystem issue.. if your computer crashes, chances are that the stuff that is running (RR/Winamp mostly) could become corrupted.. so you just need to get your system stable... I've never had an issue with it.. but I've had MPC become corrupted once or twice for the same reason.
    Ride Runner RR's Myspace
    Oct 2004
    San Diego, CA
    right... its too bad carpc's arent realy stable quite yet for most people... .im sure everyone gets the occasional reset or freeze (which is probably why it gets corrupt)
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    im trying to use winamp 5.09 but whenever i open it, even if its only just been installed, it crashes the pc, cant do a thing with have, have to hold the power buttin, anyone else seen this?
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Try Winamp 2.8... I was using 5, but switched to 2.8 and its much better
  1. Zippy vs. Winamp
    By alienjj in forum Input Devices
    Last Post: 05-17-2005, 12:32 AM
  2. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
  3. Running RoadRunner and Winamp
    By MatrixPC in forum Road Runner
    Last Post: 02-09-2005, 09:07 PM
  4. WinAmp Plugins
    By erichlf in forum Media Engine
    Last Post: 12-22-2004, 12:01 AM
  5. Need winamp 3!!! Please help!!!
    By bankingdom in forum Software & Software Development
    Last Post: 12-17-2003, 11:41 PM
