Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: SpeakEasy Voice Recognition - Beta 1
  1. #11
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    looks good this m8.. I will add some more sdk commands this week for you now that speedcams are included.. would be nice to add these through voice
    CdR
  2. #12
    Feb 2004
    Manchester
    ok had a quick play.. seems to work fine for about 3 or 4 mins, then the main screen disappears and nothing happens, the only way to close it then is by taskbar manager. Also.. 1st request :-) would it be possible to make it work like a multi remote control.. so say you are using freedrive.. you say freedrive once.. then any commands you wish, rather than having to say freedrive all the time.. like you would press dvd on the remote then all the keys are sent to the dvd.. then if you want to use roadrunner you say roadrunner, then all commands are sent to that app. ?
    Also it took me a while to figure out I needed to load the ini file.. could you load this as a default one on startup maybe ?
    this looks like its got loads of potential good work m8 :-)
    CdR
  3. #13
    Jan 2004
    Just tried it out!
    I really, really like the UI on the main screen. The help list seems to work really good.
    I think that the settings builder could be a bit easier to use.. but this is your first version.
    Overall, very nice...
    I will have some sort of voice command help in the future.. but it is nice to see something in action.
    What language is this in?
  4. #14
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Quote Originally Posted by CdRsKuLL
    OK, I should have documented the functionality, but it will take forever to write! The main window has a timeout, if you look in the settings.xml file there is a section saying: <activeTimeout>45</activeTimeout> Here this specifies how long the main window should be open and recognising commands. Once the timeout is reached it closes the window and stops recognising. You can set this to the number of seconds you want, if you set it to <activeTimeout>45</activeTimeout> then the window will not timeout and you need to press Hide or Exit, Exit closes the App completely, Hide closes the main window.
    OK, you can close the App even if the main window is closed. Notice the transparent button on the top left and side that says "SpeakEasy VR". If you press on the SpeakEasy text then it opens the main windows and starts the recogniser again. If you press on the VR part then it EXITs the App completely. Also if you right click anywhere on the Speakeasy text it EXITs the App.
    CDR, there is a LOCK command but I've left it out of the ini file to keep it simple for people at the start. Look in the vocab folder and open map.ini and add these lines, below.
    "warning disbale ***" turns off one grouping complete so if you say "warning disbale free drive" then nothing from the free drive group will be recognised. All the other groups are enabled still. You can turn them off one by one if you wish. "warning reset ***" turns the specified grouping back on.
    "warning lock ***" will lock the recogniser so it just recognises the group you specify. So "warning lock free drive" will mean only the free drive grouping will be recognised. There is one exception, the "lock reset" command which is used to turn the groups all on again. "lock reset" does the same things as the "Reset" button on the GUI.
    CDR, the extra bit you want is to not have to say the prefix like "freedrive". This can be done, I'll add it to the next release.
    Code:
    [warning disable]
    map	SE::map-disable	Listen for Map commands
    music	SE::music-disable	Listen for Music commands
    playlist	SE::playlist-disable	Listen for playlist commands
    warning car	SE::warning car-disable	Listen for Music commands
    car	SE::car-disable	Listen for Music commands
    [warning reset]
    map	SE::map-enable	Listen for Map commands
    music	SE::music-enable	Listen for Music commands
    playlist	SE::playlist-enable	Listen for playlist commands
    warning car	SE::warning car-enable	Listen for Music commands
    car	SE::car-enable	Listen for Music commands
    [warning lock]
    map	SE::map-lock	Lock Map commands
    music	SE::music-lock	Lock Music commands
    playlist	SE::playlist-lock	Lock playlist commands
    warning car	SE::warning car-lock	Lock Warning car commands
    car	SE::car-lock	Lock car commands
    [lock]
    reset 	SE::reset-unlock	Unlock Map commands
    I presume you're talkign about the Vocab Editor. Yes I'll do that it is a good idea. I'll change the filename to default.ini and make it open in the Eidtor by default, if it exists. Thanks for that idea.
    It's got a long way to go, lots on the TODO list.
  5. #15
    Jan 2005
    Spain
    Cheers FunkDaMonkMan, your Bruno application inspired me to get off my *** and write some code. The way you designed the vocab files was fantastic, it help me to see that you could make voice recognition very configurable.
    Yep, the settings GUI is vile, I need to work on it.
    It's all in C#.
  6. #16
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by ruairi
    @Laidback Cheers, I have a absoluted directory address in the settings file for the Vocabulary folder, So it would only work on my Dev machine. I've fixed this now, i hope! Please re-download and try again.
    S'funny, still getting the error box!
    It gets this far....
    Code:
    Log Entry : 09:39:30 19 May 2005
    Loaded Vocabulary: D:\Program Files\SpeakEasy VR\Vocab\map.ini - 09:39:30
  7. #17
    Jan 2005
    Spain
    Quote Originally Posted by Laidback
    Code:
    OK, there is an updated installer with more loggin and error handling. But I suspect your error is for some other reason.
    Do you have SAPI 5.1 and .Net runtime 1.1.4322 or higher?
    Download it again and reinstall it and you should get more details in your log file this time.
  8. #18
    Oct 2003
    Madrid
    Yes & yes
    Code:
    Adding Rules for : global - 12:09:30
    Error Activating Grammer in Recogniser Engine - 12:09:30
  9. #19
    Jan 2005
    Spain
    @Laidback, I've emailed you an update to try to track down this error. If you don't mind it might be faster to fix this off this thread otherwise the RR board will always have this thread at the top!
    Once we find the fix I'll update the download link.
  10. #20
    Oct 2003
    Madrid
    Re-installed Sapi and now it works!
  1. Bruno Speech Recognition BETA v1.2
    By FunkDaMonkMan in forum Bruno Speech Recognition
    Last Post: 05-03-2005, 02:03 PM
  2. Voice recognition support
    By smashr2k in forum Centrafuse
    Last Post: 12-06-2004, 02:33 PM
  3. Voice recognition using SAPI
    By djScript in forum Software & Software Development
    Last Post: 09-30-2004, 08:59 AM
  4. Voice Recognition + Database Access Over modem??
    By az1324 in forum Software & Software Development
    Last Post: 04-09-2004, 08:32 PM
  5. voice recognition (sp?)
    By blaine1605 in forum General Hardware Discussion
    Last Post: 02-04-2004, 06:59 PM
