Results 1 to 7 of 7
Thread: Minimize winamp on RR Startup
    Spring Hill, Florida
    How do I minimize winamp when RR starts. As the program is opening, I see winamp before I see the main RR screen. Any ideas?
    2005 Black Chevy Impala
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    There is an option to Hide Winamp, in RR Config up top, but it only has effect a few seconds after you see the winamp window...
    no workaround for that afaik...
    Nov 2004
    St Louis
    Quote Originally Posted by Shelbrain
    After you set the RRConfig to hide winamp like RoyN said above, close RR.
    Run Winamp alone and make sure the equalizer and playlist are turned off. Close and then run RR. Should only see a flash of winamp and its gone.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This may depend on the version of Winamp/RR you have.. I do know that I have added support to run winamp hidden from the start (when using the hide winamp option)... I have just tested it here and seems to work.. not sure if this was a feature on version 5-12...
    Ride Runner RR's Myspace
    May 2005
    Copenhagen - Denmark
    Start Winamp -
    right click on winamp in the status area of the taskbar and select Winamp
    or
    right click on winamp in the Systemtray
    and uncheck
    [Main Window] ( Alt+W )
    [Playlist Editor] ( Alt+E )
    [Video] ( Alt+V )
    [Media Library] ( Alt+L )
    [Equalizer] ( Alt+G )
    restart Winamp
    Concider this:
    If you uncheck both [Show Winamp in Taskbar] and [Systemtray] and hide the Main Window as well, ( I wouldn't recomment it ), you will have to use the taskmanager to "get in contact" with Winamp again:
    Right click on Winamp - select maximize - this will bring Winamp out, if this doesn't do the trick then Right click on Winamp - select minimize - Start Winamp again and select maximize.
    Testet with Winamp 5.09
    Ok thanks, I will try those. I am running Winamp 5.09 and the latest RR config.
    Constant Bitrate Cobelli's Avatar
    Jun 2004
    Also make sure you are using the classic winamp skin. The modern one doesn't always seem to respond correctly.
    - Cobelli
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  2. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  3. RR hang due to WinAmp dialog.
    By Arathranar in forum RR Bug Tracker
    Last Post: 04-06-2005, 08:19 PM
  4. Occasionally winamp uses almost all the cpu slowing down RR
    Last Post: 03-22-2005, 12:38 AM
  5. Slow playlist load at winamp startup
    By xa0s in forum Software & Software Development
    Last Post: 08-18-2000, 11:16 AM
