Page 1 of 8 12345678 LastLast
Results 1 to 10 of 76
Thread: RR 05-28-05.. Early Release..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 05-28-05.. Early Release..
    Ok, Editing the Brushmetal skins has taken a whole lot of time from me.. I still have to adjust/change the .skin files for the BrushAluminum skin (so white labels don't show on bright background, fix areas etc). I'm only releasing this now because I know some poeple have been patiently waiting for some of theose new features:
    -Added Support for Hauppauge's Radio Application
    -Added Support for keyboard key-assignment with specific screens
    -Added Support for translated commands assignment with specific screens
    -Added Support for selecting/controlling multiple sliders with control "buttons"
    -Added Control for WinDVD/PowerDVD through skins
    -Improved Restart and Power Off procedures
    -Improved Loading Time of TV Presets/playlist when starting/stopping TV
    -Fixed Minor bug with XM Listings with numbers in them
    -Fixed MM Embbeding bug on re-runs
    -Fixed bug that sometimes would close RR on skin switch running MM
    -Fixed minor bug with Closing RR after switching skins while using Mappoint
    -Fixed issue with Phone call starting winamp after calls (if winamp stopped)
    -New Redesigned BrushMetal & Brush Aluminum Skins
    Notes:
    -I still need to Update RRConfig.
    -I still need to Update Documentation
    -The Radiator path must be set with the WinTV RADIO application path to work with the WinTV
    -WinDVD/PowerDVD support is done by using the appropriate skin. Look at menu.skin and uncomment the appropriate DVD skin you wish to use. You still have to setup the DVD path information and window title on RRConfig. I can't possible support all versions of WinDVD and PowerDVD, but most of the versions I tried worked well. You should possibly set the player to auto-play, and auto-start in full screen when possible.
    -To setup "specific" keys or translation commands for certain screens, just open the INI and add: ,<SCREEN.SKIN> to the command/key definition, i.e.:
    32,"PLAY",audio_player.skin
    "MYCOMMAND","PLAY",audio_player.skin
    I have also spent a lot of time researching on performance and memory imprvements but unfortunately, my attempts were mostly unsuccessful.
    This version is AS-IS (although I've been testing it for awhile). I'm still working on it, and requests are listed in the .txt file.
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    thanks!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    ??? when do the OBDII suport Come ?????
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    I'm going to test
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Brill Thanks,
    PS: Can't get CDRIP to work....what am I missing...is there an INI
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    May 2005
    Thanks guino
    Newbie krustydawg's Avatar
    Apr 2005
    Power DVD now embeddes perfectly and playes with no jumpy screens, just what i have been waiting for
    thanks
    krustydawg
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    Thanks Guino!
    Now we have some new stuff to try out. I'm looking forward to the embedded Power DVD.
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 4u2n
    Whenever I get a chance to work on a car 1996+ model.. mine is 94...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by wizz
    Brill Thanks,
    Wizz
    This is still an incomplete feature. You'll have to edit the skin button command with the PLUGIN command to make it work. There's a INI for the cdrip, wherever you downloaded it into.
  1. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 07:48 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 12:27 PM
