Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 77
Thread: RR 06-06-05 .. Winamp Library Support ...
  1. #41
    FLAC mauri's Avatar
    Jan 2004
    Two question:
    I use the D-Link as the adio device:
    If I switch from the Audio player to the Radio, kneels me of very the volume.
    This with the new release, first it was everything ok.
    What and' the lace to visualize the speed alert:
    I have tried in Destinator_GPS.skin
    I01,630,000,30,64, "OVERSPEED:B"
    but it doesn't work.
    I have correctly drawn obviously the skin with my indicator (Dena skin)
    I have also tried to train in MM the function,( and RR settings) but only the voice of the message of MM and not indicator in RR
    Mauri
  2. #42
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What in the world are you trying to say by this: "kneels me of very the volume." ?
    For the overspeed, it works solely with the Overspeed setting in the GPS section of RRConfig. IT should "blink" if the ON image has something to show on that area of the screen and IF you're at or over the speed set in RRConfig.
    Ride Runner RR's Myspace
  3. #43
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Yes!
    Tried, but it doesn't work
    Mauri
  4. #44
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Mr.Fabio
    Hey Guino, did you taked a look to the preset problem with PhoCo?
    I just found and fixed this issue... here's a quick patch:
    http://guino.home.insightbb.com/rr.exe
    Let me know if you still have problems afterwards ..
  5. #45
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Mauri
    I still don't understand what you're saying on top of your post... "kneels me of very the volume."
    I do understand your overspeed alert doesn't work, There might be something wrong because of the addition to the MM's direction indicator.
  6. #46
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Guino, are you planning to ever include direcotry browsing straight onto the player? Basically removal of browser requirement, and allowing us to browse all of the defined folders, and a button to go UP-A-LEVEL, and then just click directory, start playing stuff in that directory and so forth?
    It will make things simpler for people who have never used the system....
  7. #47
    FLAC mauri's Avatar
    Jan 2004
    Example:
    Audio player--> volume 80% ok, strong.
    Switch to Radio player, volume the same , 80%, it drastically decreases in power....
    I check to solve the indicator speed problem...but:
    In MM settings needs to select this option or only alone in RR ?
    Mauri
  8. #48
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Example:
    Mauri
    1-even different MP3 files have different loudness, you can't possibly expect it to be the same for everything. What I do is lower the winamp volume and increase the Line In/Wave volume to where my Radio/Video/Mp3 have about the same loudness but it can never be perfect.
    2-You just need to set the speed in RRConfig. For it to work you must use a skin that has the indicator propperly defined, and most importantly use AGPS on MM.
  9. #49
    Feb 2005
    I just downloaded the new skins, there's eq preset in the volume config, but when i click on it, nothing happen? is this a new feature that will be in future release? or am i missing something? i read the readme file but I don't see it mention anything about this.
  10. #50
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Set the EQ, then press and hold to save the presets. Once presets are saved, you should be able to load them using of normal press. Presets will not work before you saved them and there's no good way to package RR with presets.
  1. RR 05-12-05... Extra FM support ...
    By guino in forum Road Runner
    Last Post: 05-27-2005, 11:37 PM
  2. Minimize winamp on RR Startup
    By Shelbrain in forum Road Runner
    Last Post: 05-26-2005, 02:09 AM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
