Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: RR 06-06-05 .. Winamp Library Support ...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 06-06-05 .. Winamp Library Support ...
    Ok, here's what I came up with for this version:
    -Added Support for Winamp Library Database (Albums/Artists/Genres Lists)
    -Added Option to remove ".." from folder lists
    -Added MM Direction Indicator Support (Thanks 307SW_NLD) (Untested)
    -Added XM Channel change (preset) skin/sdk command
    -Added Option to disable hibernate handling (for those with freeze issues)
    -Added Support For PhoCo Mixer preset (untested)
    -Added Support for Muting/Unmuting audio lines in the mixer
    -Added Support to toggle Repeat/Shuffle by clicking on indicators
    -Added Support for Alpine Skin's Search Screens
    -Added Support for polling XM Channel Info on labels
    -Improved HideMouse function to "blank" the System Cursor
    -Modified XM Satellite Signal information to reflect Quality
    -Modified PostalCode input to use the normal OSK Mappoint
    -Fixed sound issues with Direct XM<->Radio Switching
    -Updated RRConfig Tool
    -Updated Brush Metal/Aluminum skin files
    Notes:
    -Database Support (Winamp Library) is totally optional, I use file names only (because it's a lot easier to organize + it is a lot faster).
    * You can simply hit browse in the artist/album etc to browse through your DB. Hit back to start over. You can search the whole DB by hitting the search button on the DB titles or search from the current selection you made so far. You should set your watch folders/scanning settings on Winamp to your liking.
    -Haven't tested the MM Direction indicators (307SW_NLD can probably fill you in with this)
    -To Disable Hibernate Handling add: HibernateAware=False to RR.INI
    -Haven't tested the Phoco mixer stuff, but should work since I used standard/pre-tested functions to do it. You should most likely DISABLE the volume controls in PHOCO itself.
    -Tweaked the Skin files a bit, mostly text colors and such (no image changes).
    -There's a "loading banner" now -- I guarantee you that it will not slow down the start process in any way, but it will tell you what's going on. I did this so I could discard unused code from memory after loading, plus, give some user feedback. You can disable the Loader using the (Quiet) command line parameter: /Q
    -To hide the ".." from the folder lists, add this to your RR.INI: hidedots=true
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Nice! Thank You!!
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    nice job
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    FLAC ppgt94's Avatar
    May 2001
    USA
    This is friggin' great!
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Thanks Guino!!!!
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    sweet thanks!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    Thank you Guino!!
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
    Mar 2003
    UK
    Excellent, thankyou!
    Celica VVTi
    EPIA M10000 Nehemiah, 160Gb HDD, 7" Lilliput VGA Touchscreen, Opus 150Watt PSU, Slimline DVD/CDRW, Road Runner
    Feb 2005
    Italy
    Guino, I have tested the Preset for PhoCo. When a call is done or is incoming, the Phone preset is correctly loaded, but when i press the hangup button to terminate the call, the previous preset is not restored
    Fabio
    Travla C134
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Mr.Fabio
    I have to test it myself.. but did you DISABLE the Phoco volume controls in PHOCO settings -- I remember I had trouble with it.
  1. RR 05-12-05... Extra FM support ...
    By guino in forum Road Runner
    Last Post: 05-27-2005, 11:37 PM
  2. Minimize winamp on RR Startup
    By Shelbrain in forum Road Runner
    Last Post: 05-26-2005, 02:09 AM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
