Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 71 to 80 of 108
Thread: TOMTOM / Pocket PC Emulator / RR
  1. #71
    Aug 2005
    run tomtom navigator with xp and the emulator
    fine can you explain the process for install tomtom guenine or cracked version
    i an run he emulator (cradle it with emulator manager ) some problem with async , but definitly can't run tomtom aplication on ppc device
    how do you manage it please ? b rgds gui4242
    Quote Originally Posted by ctwizard
    Well ladies and gents It seems that the pda emulator and the tomtom version 5 software works. Picks up the USB GPS RECEIVER as long as the emulator is configure to COM3 Serial Port 0 (Or what ever com port your usb device is) and then in TOMTOM configure for OTHER NMEA DEVICE and select Serial Com port 1
    Works like a charm
    Thanks to all
  2. #72
    Aug 2005
    Lincoln
    To everyone who worked on this and made TomTom possible on a PC - THANKS!
    Nebs
  3. #73
    Constant Bitrate Power_nisse's Avatar
    May 2004
    Sweden
    Well i tried map monkey and was not happy with it. it did not go as smooth as for my friend who have a "Acer PPC N35" with TomTom5.
    Tom Tom 5 is the best looking, best features and smothest GPS program i have seen.
    Its a shame the Emulator takes so much CPU but im gonna try this anyway
    BTW: How the h*ll do i get this "The guest ID" on "https://beta.microsoft.com"
    Ampie Case
    M1-ATX 90w
    EPIA ITX 1,3Ghz, Firewire
    80 GIG SATA
    512MB
    7 TFT Touch Super
    Pioner Slot in DVD-RW writer
    108 Mbit Wireless Lan
    100 M Bluetooth Range
    //Power Nisse
    My Betasite -> http://haagen.se
  4. #74
    Newbie crankshaft's Avatar
    Jul 2005
    Singapore - East Coast
    OK, I have downloaded and installed ths simulator, and after a few hours of figuring out how the emulator config / command line parameters working, I have it running quite well, but I am using a localized map for Singapore which is much smaller than for the UK so speed is probably better.
    I only get excessive processor usage when doing a WM cold boot, if you setup and use a .dess file and create a shortcut to it then it's surprisingly fast. It would be good to be able to strip out the excess WMsim code from the .dess file, and that would make it even faster.
    I also have mine configured with the map data copied to the WMsim my documents folder which means that the .dess file has grown by the size of the map, and since it looks like this .dess file is a database file which holds all of the O/S and data files, it could be made quicker by mapping a 'REAL' folder with the map and possibly the application on it.
    I am going to test it running the map embedded into the .dess file as well as having the map data on a real drive.
    Cheers
    PeterC
  5. #75
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    It sounds good.
    I've tried other software with uk maps (Mappoint, iGuidance and Destinator) but Tom Tom seems to be the best all round IMO. Not to knock the excellent work by NM with Map Monkey.
    I can't get my version of TTN to install on the emulator because the machine ID is different to my PPC and the activation fails... No doubt I'll get round this soon.
    Good luck with your testing
  6. #76
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    OK, as a PPC user I have a few questions. I read through the thread and my hats off to all that did the digging and testing..
    Does the emulator act like another PPC within ActiveSync ????
    without external hardware of course.
    So that you would install applications into the emulator just like the PPC.
    Someone mentioned that the Epia motherboards support Win CE ..
    How would you do that ??? I upgraded my CE2.0 on my Ipaq 39xx via the USB boot feature from the PC. I don't even think that I have the original CE CD, as it was like 5 years ago.
    Don
  7. #77
    Jul 2005
    Hampshire UK
    The emulator gives you a window with generic ppc controls, WM2003SE. It can access your hard disk like a CF/SD card. It is very processor intensive whilst booting up...
    as for the epias I don't know, sorry.
  8. #78
    Oct 2004
    Regarding the problem of 100% cpu usage while running tomtom via the emulator, would THIS solve the problem?
    http://www.allcam.biz/products/u-box.html
    Can this really be hooked up to a car battery?!
  9. #79
    May 2005
    Germany
    Hello,
    I hope someone can help,
    I installed Microsoft Pocket PC 2003 SDK and Emulation Images. What else do I need, to run TomTom on my PC. ActiveSync is installed on my PC, too.
    EDIT:
    It would be nice if someone could make a "HOW TO" like:
    1. What do I need
    2. How to install
    3. How to run the Programm
    Ti-ejtsch
  10. #80
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    The WM 2005 Emulator is out.... http://www.mp3car.com/vbulletin/show...007#post663007
    Terran
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Replies: 2
    Last Post: 06-10-2005, 10:59 AM
  3. Pocket PC and Laptop GPS Software
    By faz211 in forum GPS
    Last Post: 09-18-2004, 04:56 PM
  4. Pocket Control PC! smartphone app
    By snmnetwork in forum Input Devices
    Last Post: 09-14-2004, 06:38 AM
  5. FS: HP iPAQ Pocket PC h1910 w/ Stereo Earpiece
    By astral in forum Classified Archive
    Last Post: 08-03-2003, 02:18 PM
