Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Problem whit cdrip whit rr
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    make sure the CDRip is not loaded/hidden in the background, I suggest restarting the machine, the above works really well. This is all you need:
    Main menu: "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe"
    In the cdrip.skin exit button: "EXITPLUGIN"
    In the exectbl.ini:
    "QUIT","SendMsg;RRCDRip;showplugin||BYE"
    "BYE","QUIT"
    Ride Runner RR's Myspace
  2. #12
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I download the ney version and the skin again..... also add a exit button to the jpg.
    But I'm lost in what the label for the button is ....
    I checked the .skin file but I don't see the label for minimize
    Thanks...
  3. #13
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by thanatos106
    Thanks...
    Just add this to cdrip.skin:
    B99, 000, 000, 100, 060, "MINIMIZE", ""
    It will create an "invisible" button at the top-left of the screen. The numbers are X,Y,Width,Height.
  4. #14
    Nov 2004
    got it!!!!
    I wasn't sure on the content......
    But this answer my question pretty good!!
    Thanks guino
    edit:
    Work like a charm.....
    1000 thanks for support a non RR user
  5. #15
    Oct 2004
    Quote Originally Posted by guino
    In the exectbl.ini:
    "BYE","QUIT"
    Ok I have modified exectbl.ini, the button exit in cdrip.skin and the button rip in main menu. When I press the push-button exit in cdrip, the plugin cdrip it is closed and rr it continues to work but hidden. I have tried to insert the following command in cdrip.skin: "SENDMSG;RoadRunner;close" and when I press the button exit in cdrip it to hidden and returns rr, but cdrip continues to work but hidden. All this goes well, but as I can close cdrip without to use taskmanager.
    Note :
    also when use the commando minimize, hides all and not only cdrip
    thanks
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Post those three files ZIPed: CDRIP.SKIN, MENU.SKIN and EXECTBL.SKIN -- I'm sure you have something wrong. Do not post your "modified" version I want the version as you see is what I told you to do..
    EDIT: one thing just hit me.. you mentioned running the CDRip OUTSIDE RR.. when I'm talking about editing CDRIP.SKIN I am talking about the CDRIP.SKIN file in the SKIN FOLDER OF RR -- NOT the skin you point the cdrip.ini onto. I have mentioned that you should download the CDRIP Skin into RR's skin folder, but I just wanted to be sure.
  7. #17
    Oct 2004
    OK I have attached the file.
    They are curious to understand where mistake.
    I have fear of to have become stupid.
    notes:
    I have attached also an image of what I have within the folder of of the skin of rr
    Attached Files Attached Files
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, for my surprise, although your files look right, it did what you said (RR became hidden when exitting the plugin).. The problem is that I found a "bug" in RR on the plugin command.. basically if it doesn't have the exact Window name of the plugin, it won't find it and it wont work. I recall doing that on purpose (but even I forgot it, so may want to improve that). Open CDRIP.skin in RR's skin folder, and change:
    to:
    "PLUGIN;RRCDRip;C:\Programmi\Road Runner\CDRip\CDRip.exe"
    That should work (for now).. I'll make sure this is not an issue for next version..
    (Note the lower case "IP" in RRCDRip ..)
  9. #19
    FLAC J187's Avatar
    Nov 2004
    Boston
    I'm having the same problem, whereas when I close plugin RR disappears but stays running in processes. The command in the CDRIP.SKIn file is "EXITPLUGIN". What do I have to do to correct this?
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is all you need -- MAKE SURE EVEN THE CASING IS THE SAME -- COPY/PASTE to be sure:
    Main menu: "PLUGIN;RRCDRip;C:\Program Files\Road Runner\CDRip\CDRip.exe"
    In the exectbl.ini:
    "BYE","QUIT"
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 08:13 PM
  2. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 05:09 PM
  3. hibernation problem
    By btbe in forum Road Runner
    Last Post: 04-13-2005, 06:30 AM
  4. problem updating RR?
    By Rs! in forum Road Runner
    Last Post: 03-16-2005, 12:21 PM
  5. RR 2-27-05 Audio Browser problem
    By Curly_cat in forum RR Bug Tracker
    Last Post: 03-02-2005, 01:40 PM
