I don't think the cddb local is working yet ... only internet based cddb.
Hi Guino![]()
I have two problems with cdrip:![]()
1) I do not succeed to close cdrip without to make to hide rr. In fact when I press the button exit in cdrip it closes itself but rr it hides and is visible only with taskmanager.![]()
2) I do not succeed to make to work cdrip with the cddb local. I have unloaded from Internet cddb (362 Mb) and have inserted the path in cdex ( option, setting , cddb locale), but it does not work. In fact if internet is not active , cdrip does not recover the information.
note :
with cdex the cddb local it works well
how I can say to cdrip recovering the information from the cddb local?![]()
You can help me?![]()
therefore the access to the cddb local is a function not implementedthat guino it could implement?
thanks
Originally Posted by UK_MP3Car
1-you're probably not using then PLUGIN command to run it.
2-I haven't implemented that yet, just need to find time to do it.
Ride Runner RR's Myspace
1- okOriginally Posted by guino
2- ok as soon as you can.![]()
Guino I have noticed that when I press the button exit, rr it does not return in main menu but remains cdrip and on the bar of the applications flashes RR. If I press on rr on the bar of the applications it it appears and if from the main menu I press button the CDRIP appears the image of RR Loading, but it does not happen null. I imagine that it is a problem which had to the fact that cdrip is still experiences them? As usual I enclose one photo in order to understand to you to us better. Thanks
NOTE :
I use "PLUGIN;cdrip;C:\Programmi\RoadRunner\CDRip\CDRip. exe" in the main menu and "SENDMSG;RoadRunner;exit" for exit button in cdrip
The Plugin name to use in RR is RRCDRip and not CDRip.. once you fix that, RR will acknowledge and control the Plugin (because then it will be able to talk to it). So use:
"PLUGIN;RRCDRIP;C:\Programmi\RoadRunner\CDRip\CDRi p.exe"
Note that the CDRip will stay running if you close RR. You'd have to change the exit button code (CDrip.skin) to "QUIT" to make it quit when exiting it's skin (this prevents you from using other screens of RR while ripping a CD on the background).
Ok, I've worked a bit on the CDRip today.. added a minimize and a exitplugin "smart" command to the plugin. For minimize you'll have to edit the skin images to make a button for it (to run in other front-ends).
You should download the CDRip binary package from my site along with the Skin for it (unzip skin package in the BrushMetal folder if using in RR -- or at least the cdrip.skin file).
You should add those TWO lines to ExecTBL.INI if you don't want the CDRip hidden on the background when exiting RR (and the CDRip is busy).
"QUIT","SendMsg;RRCDRip;showplugin||BYE"
"BYE","QUIT"
I'll post updated FULL skins when possible...
excuse guino
I have made as you say, and the result is:
launch rr,
I press the button rip in the main menu, appears cdrip.
I press the button esc in cd rip and the result is that rr it is closed, but cdrip is run.
Where I am mistaking?![]()
note:
In the main menu i use : "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe"
In the cdrip i use "SENDMSG;RoadRunner;quit"
In the exectbl i added this line :
"BYE","QUIT"
You did NOT download the CDRip SKIN as I told you to do. Did you even download the Updated CDRip Plugin ? If so, just change the EXIT button code on CDRIp.skin to: "EXITPLUGIN"
This will TERMINATE RR: "SENDMSG;RoadRunner;quit" (you don't want that).
ok guino
I have made confusion.![]()
Hour I sure have new cdrip and the new one skin of cdrip.![]()
When start cdrip from the main menu of rr, appears the image of loadin, but it does not succeed null, it seems that rr it jams. I have tried launch cdrip without rr (setting up the path for the skin) and works. In main menu I am using this command: "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe" What has happened now?![]()
thanks for your patience![]()
