Originally Posted by
guino
I don't know what you mean be "defective" . Fact is, RR just tells winamp to play the .CDA file so it should be the same in Winamp or in RR. My best guess is you have too much stuff running on the background hogging the CPU -- specially if you have a slower CPU. Run Winamp outside then run your GPS application with it and whatever else you may be running to see the problem exists. If not, make sure you've done the flash update in RR and check the processor usage with Task manager.
