Results 1 to 10 of 17
Thread: wintv usb locks
    May 2005
    Rochester, NH
    wintv usb locks
    I have noticed for sometime now that my tuner wasn't working right, I havn't really used it much yet cause I listen primarialy to music, but decided I wanted to listen to the radio today and found that it tunes in and works fine for about 10 to 30 seconds, sometimes longer, then it just like shuts off. Almost as if the sound card is getting muted, but I have checked that and thats not the case. I think instead the tuner is just screwing up. I have tried different things with radiator and it doesn't seem to make a difference.
    Has anybody had this problem? Could it be the hauppauge is bad?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    let me get this straight: you're using RADIATOR with a WinTV card ? why ? You should install the WinTV radio application and set it's path+type in RRConfig. It will work a lot better. I have seen many cases in which Radiator freezes up with some cards/drivers (even when setup propperly)... this of course, depends a lot on which card you have..
    Ride Runner RR's Myspace
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by guino
    Yep.... I agree... since you implemented this... I've been lovin it! Scan finally works properly! Thanks again Guino!
    May 2005
    Rochester, NH
    ok, last I knew I had to use radiator. How do I know if I have the right version of roadrunner to do this? Is there any writeup on setting up the wintv application with roadrunner?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's exactly as I said above:
    -install the WinTV radio application from Hauppauge (300Kb)
    -Select WinTV in RRConfig
    -Set the WinTV RADIO path in RRConfig
    The above is all you have to do. Nothing to configure in the wintv radio app and no need for radiator either. Should work as fast as the wintv radio application does. Just make sure you have one of the latest versions (i.e. 6-6). You can probably just upgrade your RR using the update tool if you installed using the installshield.
    May 2005
    Rochester, NH
    Ok, well I definitely didn't have that version of road runner, I have it now, but I'm still having the problem. I think there must be something wrong with my tuner unit, it just hums and won't tune anything in, so I'll have to contact hauppauge and see if they can figure it out. It does the same thing in just the hauppauge software as in roadrunner, so I don't think its road runner. Oh, and thanks for the minimize guino! I have wanted that from day one!!!
    May 2005
    Zagreb, Croatia
    Maybe your antenna is not functioning.... Try connecting the antenna from the car to the appropriate inlet.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It could be as simple as pluggin the FM antenna in the TV plug. You should always test in the Hauppauge Application first (so you know the hardware works).
    Oct 2003
    Question: I have the version of the USB tuner that just shows up as one USB device. Therefore, it can not be muted. This is fine for a the first launch - RR unmutes the USB device when WinTV starts, but unfortunately it says on even if I exit the radio section. Is there any way to make it go back to mute when I ext the radio section?
    Thanks,
    Dan
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The WinTV Radio application is who should take care of that. Does it stop if you run it outside RR ? If it doesn't, then you'd have to make a bat file and to "restart" the USB device altogether. But this would likely have to be a "manual" process as there's no good place to automatically run such event.
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  3. Replies: 6
    Last Post: 05-08-2005, 12:53 AM
  4. stupid usb slimline DVD drive
    By ummagawd in forum General Hardware Discussion
    Last Post: 04-26-2005, 02:57 PM
  5. USB Soundcard Woes
    By phc in forum General Hardware Discussion
    Last Post: 02-11-2004, 06:02 PM
