Results 1 to 10 of 11
Thread: What is normal CPU usage for RR?
    Jul 2002
    With the new 6-6-05 binar and BMV2 skin with the Honda logo, my CPU usage hovers around 80% at all times, peaking at 99 often. It feels very very sluggish too. I unregistered/uninstalled flash and reinstalled Flash 7, and tried the suggestion in the FAQ. Could it be that flash skins are just that taxing?
    It runs fine on my other 3 computers, just not my carputer. Carputer is a Celeron 2.4ghz, with 256mb RAM.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Hm, I don't think I have the flash logos as I don't actually like them, but without, it should be only like 2-15 fluctuating, depending on what RR is doing. Loading screens, it'll borrow some CPU but only momentairly. Try using another skin or taking the flash logo out and see if its flash that's doing it
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Actually I just checked and I do have the flash logo. STill at 15%
    Please help.
    Gender is Questionable ibrennan's Avatar
    Jun 2004
    Moorestown, NJ
    i have this same problem, did everything that was posted like upgrade flash and stuff.....i still have the problem....so i just took the flash out of the skin and was going to figure it out later...i am glad that someone has the same problem i do though
    also it never did it with any of the older versions of RR, just the 6-6 one
    2001 Explorer
    Xenarc, Opus 90W, 120 GB HD, Bondo everywhere
    Sold the Explorer...got a 350z
    Jul 2002
    I removed the Flash from the Skins with the editor and it went back to low usage. Everything was real snappy. Loaded a skin with flash and it jumped back to full load. So, the problem is definitely flash. I just wonder how it can be fixed. I've tried unregistering all flash, loading up just flash 7 and it's still bad. Then I tried just registering the flash in the zip from the FAQ, and still bad. Then I did them consecutively, and it's still bad. What other dependencies does flash have besides the ActiveX control?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah, the Flash player can load up the CPU -- specially if an old version of Flash is installed. What a lot of people don't pay attention is that you MUST use Internet Exploer to install the flash player -- FireFox/Opera/etc will not do the trick. I haven't changed anything with the flash support for awhile. Even the Few % cpu load when RR is open is typically winamp playing music. RR most of the time should not even use 1% of CPU (see below)... of course this will vary with your processor...
    Ride Runner RR's Myspace
    Low Bitrate l0gic's Avatar
    Essex - UK
    I'm currently getting RR CPU usage around the 50 - 60% which, I suspect, is the reason that rr goes a bit unresponsive when changing screens.
    To be honest, I'm not too fussed about having spinning logos - I'd rather have a responsive front end.
    How do you remove the flash from the skin?
    Is it a case of just deleting / renaming the logo.swf or will I need to edit the skin to remove the flash references?
    Kevin
    Build status {..........|} 99%
    All installed - now into the fiddling about stage
    Car:MR2
    MB: EPIA C800
    Display:Xenarc 700TS
    Power:PW-70A & ITPS
    Mem:384MB
    HDD:40Gb Maxtor Diamond max
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    I have done this test some time ago on my CarPc with Logo spinning on the main menu, VISU active and music Playing, GPS running, NetStumbler searching, PhoCo Active, and MotherBoard Monitor running. In this conditions my CPU is load at 60/70%, with some peaks over 80%. Very good result i think.
    However i suggest strongly to use Motherboard Monitor to keep control on the cpu temperature. Usually when the load of the cpu is high for much time, you can risk to kill your processor!!!
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    FLAC J187's Avatar
    Nov 2004
    Boston
    MR. Fabio, the funny thing is, had you turned off your vis, your CPU Usage probably would have dropped another 25%
    Please help.
    Feb 2005
    Italy
    Yes, it's true, I have done this test to see how the system responds in extreme conditions
    Fabio
    Travla C134
  1. onboard video vs a video card, power and cpu usage
    By stapan in forum General Hardware Discussion
    Last Post: 06-09-2005, 03:43 PM
  2. cpu usage using 100%
    By michaelrj9 in forum Road Runner
    Last Post: 05-08-2005, 08:11 PM
  3. High cpu usage when audio is muted.
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-23-2005, 04:51 PM
  4. Hi CPU usage on certain MP3s.
    By ZenerDiode in forum FrodoPlayer
    Last Post: 02-27-2005, 03:13 PM
  5. winamp cpu usage
    By awh4992 in forum Software & Software Development
    Last Post: 01-07-2004, 11:13 AM
