Results 1 to 3 of 3
Thread: winamp vis
    Constant Bitrate corsab's Avatar
    Mar 2004
    winamp vis
    is possible embedded ,in audio skin, the winamp vis in a little windows?
    now when i launch the visu, i see thewinamp front and the winamp visu windows.... idon't like it
    My Home page
    Cartuper V2
    Epia M1000
    512Mb ram
    Hdd 40 Gb 2,5'
    Dvd recorder DL Panasonic
    Lilli 619 7' with TS
    SoundBalster Mp3+ USB
    Holux Gpslim236 usb + external antenna
    M1 Atx
    Remote control with girder
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    You have simply to check the "Hide Winamp" in RRConfig
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    FLAC J187's Avatar
    Nov 2004
    Yes, possible. Like Fabio said, one thing you need to do is check hide winamp. The next thing is to make sure that the visualization settings jive between winamp and RRConfig. Either Mildrop, AVS or other (You select windows title). Then, if you like, you can adjust the size the plugin appears on RR, for this you will need to search the forum there was recently instructions given on how to do this. If it helps your search, use my name - I was part of the discussion as was Guino. Good luck.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  1. WinAmp visualizations in Windows Media Player (almost working)
    By NoPistonPC in forum Software & Software Development
    Last Post: 08-21-2007, 07:11 AM
  2. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 07:16 PM
  3. Questions about MediaCar Winamp vs. External Winamp...
    By Urinemachine in forum MediaCar
    Last Post: 07-21-2004, 02:33 AM
  4. winamp cpu usage
    By awh4992 in forum Software & Software Development
    Last Post: 01-07-2004, 11:13 AM
  5. Configurable vis plugin for winamp
    By darkwingduck in forum Software & Software Development
    Last Post: 07-26-2001, 10:53 AM
