Results 1 to 5 of 5
Thread: Help with External GPS on RR
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    Hi
    I shall make this brief and to the point:
    I load my external gps program from within RR, now, should I go back to RR, is their anyway to switch back to the gps software without another copy of it being re-opened?
    Basically I want 1 copy of my external gps (infomap navigator) to be loaded, and then when I click on the gps icon in RR for it to revert back to the already open copy of nav, not a new one.
    Is this possible? If so, how? I would like to just be able to click the gps button if poss, and it detect if it is already open or not.
    Cheers
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    RR looks for a already open copy of your software first, before launching another copy.. so you should be fine
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your GPS Window Name is wrong, it will never re-run the application if the setting is right. There's a FAQ on finding the correct Window name and on running the GPS application on it's own screen. Navigator is a very poorly written application which will have many issues when embbeded. It is probably easier to run the application with the run command then minimize RR while running it, then to run it embbeded. Read Skin Commands.txt for more information. I also recommend reading the other FAQs available.
    Ride Runner RR's Myspace
    May 2004
    Somewhere in the UK
    oh
    ok. Thanks for that. Looks like i should get a different gps package then. What do u recommend that works perfectly, is cheap, and for the UK market?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For cheapest, probably Routis/Iguidance (not the best for touchscreen).. For best interface/maps/quality, Mappoint or Destinator 3 (Map Monkey/FreeDrive).
    You can try out destinator for $15 bucks last I remember (CD+Maps)..
  1. KPH to MPH in RR GPS
    By pnevai in forum Road Runner
    Last Post: 03-16-2009, 04:46 PM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
  4. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 01:47 AM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
