Results 1 to 5 of 5
Thread: Wintv usb2 help, mpeg graph not connecting
    Ft Lauderdale, FL
    When I start the winamp plugin I get an error saying. "MPEG graph cannot connect", then if I close it and try again i get "Can't connect capturer to mpeg demux".
    The plugin does open but I don't have access to the scan for channels button.
    Anyone help with this?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's normal to get an error the first time you load the plugin. Just make sure you select the device and capture settings on the plugin and restart winamp -- This is in the FAQ. If everything fails I suggest deleting plugins.ini in your winamp folder because sometimes (specially when the device isn't present) the plugin tends to mess up its settings.
    Ride Runner RR's Myspace
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Hello, I'm experiencing the same problem with my DVB-T usb card... Tried to close and restart many times but is always the same error... What can I do to solve this? Thanks in advance for support!
    Low Bitrate crispyrabbi's Avatar
    Nov 2006
    Have you checked that your DVB-t is supported by the winamp tv-plugin? I think the homepage is still up and running on
    AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
    Nov 2006
    it's all ok
    do you need to install mpeg2 decoder... i use cyberlink decoder and can you download all codec and decoder as k-lite codec pack full.
