I just got the sources from this thread, I'll look it over and hopefully add an option for next release .. it is NOT currently on the 9-30 release.
i thing sell my mobo and buy other... is sad that my carpc not resume good.![]()
Ride Runner RR's Myspace
Thanks guino.
Just checking if it was me going crazy.
Updated mod for 9/30 release is attached. Like before, lets consider this a beta release, so use it at your own risk. I've tested it in my carpc, and it appears to work correctly.
To install, browse to your RR install directory. For backup purposes, rename the existing RoadRunner.exe to RoadRunner.bak or whatever you prefer. Then replace this exe with the one provided in the zip file.
The basic mod is the same as I posted previously for the last RR release. This time around I had more familiarity with VB6 and the RR source, so it should be less quirky.
Basic Algorithm: The code keeps a timestamp that is updated every second. If between updates, more than 60 seconds has passed, I have assumed the system has just resumed from hibernation and call the RR resumeFromHibernate function to restore the skin, music, ports, etc. NOTE: For testing purposes, please wait at least 60 seconds while the carpc is in hibernation before powering it back on so that the mod will trigger.
Please post your results. I can't promise to work out the bugs, but I'll try as time permits. If its stable, I'll pass along the mods to Guino to incorporate into the next release.
-TJ
Smart Playlists Plugin for RoadRunner
CarPC - 05 Acura TL Navi (pics soon)
Retired CarPC - 03 Infiniti Qx4
ThanksThis has been an annoying problem - clock stay frozen until mouse movement. It's not RR tho' because it do the same with other FE's I've tried.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
Thanks Guino and tejesh83, i not sell my mobo until i can see next release of rr.
3 resumes from hibernation and it's working flawless. Clock does not freeze and i get instant reading from GPS.
M2-ATX Power Supply
Windows XP SP3
i'll be trying this out also..
I've had this problem for ever,, some updates seemed to have fixed but then it was back agian right away..
Still goin' strong after many returns from hybernation.
M2-ATX Power Supply
Windows XP SP3
after 2 days its been working fine..
nice work
