I'll try it later. I guess I have to DL and install the latest version of RR then, correct?Originally Posted by guino
Michael
you can try this:
-Remove the hibernateaware line from RR.INI
-Open ExecTBL.INI from the last update, make these changes:
"ONSUSPEND","CLOSEWINAMP"
"ONRESUME","STARTWINAMP"
If that doesn't work, I assume this has to be some kind of hardware/driver issue unrelated to RR and winamp.
Ride Runner RR's Myspace
Michael
uhh... yeah.... if you tried the hibernateaware without one of the latest RR versions that it woudn't work either. But all you need to do is download the binary package, and unzip the RR.EXE and ExecTBL.INI files ONLY -- no need to mess with any settings (this way).
Well, then I will do the binaries, and then test the INI hack once again, and if that doesn't work, move on to the TBL hack.
Michael
I bet you'll find that it will do it with any frontend, I have the same problem with centrafuse or frodoplayer. After hibernation you have to touch the screen to get the computer to start playing music again. I have tried 3 motherboards with the same result. But my shuttle XPC would come out of hibernation and start playing music with no problems.
肚子笑痛了
S60 Install
Hmm, I have only used one mobo, several xp installations...
at first I was using NMC... I would get music about 1 second before my desktop/frontend would reappear... basically, coming out of hibernation I would get "Windows is resuming.......................................... ........."MUSIC STARTS"..."Back to Frontend...
Then I think I started having problems after a while of using RR (I *think* the really old versions didnt have this, but maybe it happened when i switched from NMC to RR)...
I tried on my laptop and RR hibernates fine without touching ANYTHING. Could you maybe add a command that we could put in ExecTBL to try and move the cursor manually 5 pixels or something? (Of course we must give a slight delay... maybe 2 functions WAIT;500||MOUSEMVX;-5 to wait 1/2 second, and then move mouse -f pixels on X axis? Dunno, just a suggestion
Roy
2005 Range Rover 4.4
I like that idea. Have no idea how practical it is, but I like it anyway.Originally Posted by RoyN
Michael
it would only really be useful if it solves that problem!![]()
Roy
The effect you got with NMC is the result of IGNORING hibernation.. you can do that by using the hibernateaware=false setting in RR.INI... I'm pretty sure the problem with the music is something winamp related, while I can't prove it (nor debug it, since I've never seen it), have you tried to open winamp (ALONE) hibernate and resume (while playing music) to see what happens ?
For moving the mouse you can use "CTRLLEFT" or "CTRLRIGHT" (will move the mouse away from the screen). I'd try those two settings in ExecTBL.INI:
"ONRESUME","CTRLLEFT"
or (close/re-open winamp for a "wait" effect):
"ONRESUME","STARTWINAMP||CTRLLEFT"
If the above doesn't work then it's unlikely any SOFTWARE operation will be able to simulate the mouse move for your hardware to work -- In my opinion something with the mouse driver could be "locking up" when resuming and preventing any other application from receiving the "RESUME" message from windows ... but then again I can't be sure since the hibernateaware=false settings seems to have no effect.
Yippeee, the INI hack worked for me with the latest version of RR.
Michael
