Me too... is there any sort of fix for this.. it stopped doing it for a while but then when I got the most recent version it did it again..
So have anyone solved this problem? I'd like not to touch the screen everytime i start my car.
Any solution ?? i dont like need buy any mecanical finger that touchs the screen every time that start my car.![]()
I have last Roadrunner.exe
I put "Hibernateaware=false" in my config file and that works just fine.. My music resumes fine every time now..
At last, I run into this problem.
Change Hibernateaware=false will resume music but the screen isn't refresh. That mean, if I don't touch the screen or RR to be specific, all labels and stuff in RR will never update.
An example of that is in GPS mode. After came back from hibernate, music play fine. GPS working good. I enter destination in IG via TS. Drive to my destination 30 minutes later and RR still isn't update its labels. Because I never touch RR when entering the destination address in iG.
I try move the mouse (CTRLLEFT), send keystroke using ONRESUME event. Still nothing works to refresh RR.
I'm not sure what is the problem. Could be Sound/Video/other drivers+hardware that cause the problem. Same RR exe (and settings basically identical) in my other install has no probem.
My point is RR isn't really the source of the problem but could be part of the problem.
The one that has problem is the DELL GX150 1GHz, Onboard SoundMax, RIVA TNT PRO (DELL).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I also have a hibernation problem. Don't know if it's really relevant here but i'll give it a go. Sometimes, not always, when the PC comes out of hibernation roadrunner doesn't respond to the touchscreen.
Actualy it works as long as I stay in the same screen. When I leave for instance music and go to the main menu suddenly RR doesn't respond any more. When I "alt-tab" to Ibuscomm or anything else and back to RR it works again in that screen. When I leave the screen, same problem. Restarting RR fixes it. Any idea? I run Enforcers iDrive skin.
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog-My Install -iDrive F01 RR Skin
I fixed the above problem (screen isn't refresh after coming out of hibernate) by using girder's OnResumeSuspend event with moving the mouse up-right about 4 point. Work like a charm..
Hmm, don't use girder but an interesting idea.
Very interesting......... What version of girder are you using? same enforcer, i don't use girder but this night i don't sleep testing your idea hehehe![]()
I use the last free version which is 3.29.
