Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: RR 06-21-05 ... Improvements and Fixes..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 06-21-05 ... Improvements and Fixes..
    On this release of RR:
    -Added Local DB Support to CDRip (Windows FreeDB format)
    -Added skin commands: "PREV2" and "SEEK"
    -Added "ONSUSPEND" and "ONRESUME" events
    -Added commands to open/close Winamp
    -Added commands to Detatch/Embed Map Monkey (split GPS screen support)
    -Improved Phoco integration (various fixes)
    -Improved RR's Menus to allow calling of any menu from any menu
    -Fixed issue with using PAUSE/RESUME commands on XM with Line in plugin
    -Fixed Custom Label variables in Flash
    -Fixed bug with Winamp Library if winamp not in default path
    -Fixed bug with SDK taking focus away from FreeDrive
    -Fixed bug with Web Browser not embedding propperly on first run
    -Improved Internal Interfacing of CDRip plugin
    -Updated Brush skin files for CDRip
    -Added Phidgets 8/8/8 Temperature Reading support (Tested and PATCHED)
    Notes:
    -Local CDDB MUST be the uncompressed windows format. If you wish to compress it you can create a compressed NTFS virtual disk using FileDisk or use DriveSpace (Win9x/Me) -- You'll reduce the size about 600Mb.. No, I can't make it work out of the RAR package, also making it work with a Zip package would require you to re-compress it and also would make it quite a bit slower.
    -"ONSUSPEND", "ONRESUME" commands are optional and can be set on ExecTBL.ini
    -I made a "virtual" command on ExecTBL.INI simplify the setup of the CDRIP plugin. Just set the path for it in ExecTBL.INI and you're done.
    -Haven't tested the phidgets interface, but I just "copied" code I've seen posted. You can use "c2f", "f2c" and "" as format to display the values in C, F and raw value respectively.
    Look at skin commands.txt for other commands/changes.
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    look good, good job
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Thanks Guino
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Aug 2004
    Will check it out thanks
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Thanks Guino!
    The MM Detatch/Embed makes MM work perfectly.
    Low Bitrate F4kk3r0's Avatar
    Mar 2004
    Finland
    How do you install the CDDB?? im so stupiiid???
    FLAC J187's Avatar
    Nov 2004
    Boston
    HEHE, I beleive as of yesterday morning you were experimenting with CDDB Local. Then, all of sudden, you're like bam new RR release with tens of thousands of updates - damn you work quickly. Exciting changes! Especially 1st try web browser embedding.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by F4kk3r0
    -Download: ftp://ftp.wu-wien.ac.at/pub/info/fre...n-20050104.rar
    -Unpack it anywhere in your HD
    -Open CDRip.ini
    -Set: localdbpath=<PATH WHERE YOU UNPACKED THE CDDB>
    -Save
    That's it...
    Nov 2004
    I have updated the Install to include this version and all updates to the Skin.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Web Browser still not embedding propperly on first run.
    Anyone else having the same problem of the Web Browser still not embedding propperly on first run.?
    updated Road Runner using Road Runner Updater and also tried downloaded the updated skins but does not help.
    It does embed corectly but then it "pops out in front" the fist time. after the first time it is perfect.
    No big deal just thought if anyone else has this problem still.
    Thanks Guino for all your hard work with this Great Frontend.......
  1. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
