Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Strange problem with CDRIp
    FLAC J187's Avatar
    Nov 2004
    Boston
    Ok, So, CDRip is working fine in my house on my home pc. I recently updated to new RR Vers and everything is still fine if not better. I copied my whole RR Directory, skins and all, onto my carPC. Now, CDRIp loads correctly with skin, but will not read from CDROM. It won't display tracks. I tried updating ASPI. I suppose the problem could be with the drive number setting but Ive tried 1-6 nothing works. Any ideas? Also, how exactly should we know the drive #? I'm only familar with drive letter, Ive never seen a drive # setting.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    just look in cdripcls.ini ... the drive numbers are in the order your drives are listed in there.. did you remember to run "presetup.bat" in the computer you copied the files onto ?
    Ride Runner RR's Myspace
    FLAC J187's Avatar
    Nov 2004
    Boston
    Yup I remembered to run presetup. I looked at CDRIPCLS.INI and drive number is 1 which is what CDRIP.INI has. CDRIP Does load and go into memory - I see CDRIP.EXE in processes - and I do get the skin to load, it just doesn't read from the CD ROM. I've tried two cD ROMs in there now too. I also copied the RR Directory to another computer and tried it and CDRIP works fine there too. It just won't work on my CARPC. This is annoying problem.
    Please help.
    FLAC J187's Avatar
    Nov 2004
    Boston
    OK, heres one big difference - When I look at the CDRIPCLS.INI in my house vs my car, my house shows this at the top
    [JLMS____XJ-HD166S_______]
    My car shows this
    This is the CDROM, Why would it not be reading it? I have actually taken the CD Rom from my house outside and put it in the car and it still doesn't work
    Here are the CDRIPCLS files
    The one on the right, Under the heading "Freeze" Is the non working car. The other is from my house pc which is fine. The differences I see are highlighted.
    Please help.
    Raw Wave
    Jun 2004
    On the beach
    Hmmm ... check the ASPI versions on your CarPC
    Can you read data cds in the car?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Yes I can read Data fine. I tried Updating ASPI in my car, I guess I never considered it could have been a bad update. Anyway, the plot thickens a bit. When I remove the CD ROM from the car and bring it inside to a different machine and hook it up. I run CDRIP and THE CDRIPCLS.INI recognizes the drive perfectly fine and the INI file starts with [LITEON CD-ROM LTN5326S].
    SO it's definitely a problem with settings on my CAR PC. I can only think of ASPI. I'll try another update.
    Please help.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I was going to suggest that.. you can probably try another aspi based application (audiocatalyst/audiograbber etc) to verify the ASPI is propperly installed. I always have trouble with that myself... once the drive is detected, it should work fine.
    Raw Wave
    Jun 2004
    On the beach
    download aspichk32 from adaptec, should tell you whether aspi is installed properly or not.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    now, that's questionable.. I have 2 different applications (one from Adaptec) to check aspi install, and most of the time they only check for files.. I've seen both of them say my ASPI is ok and it still didn't work. The only aspi installer I trust is the one that asks to reboot after the install (the others that I've tried never worked right).
    Raw Wave
    Jun 2004
    On the beach
    I used to swear by aspichk! No wonder nothing ever worked! lol
  1. Strange USB 802.11b problem on EPIA M-II
    By DrDeriv in forum General Hardware Discussion
    Last Post: 04-08-2005, 08:59 PM
  2. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 11:55 AM
  3. strange video problem.... screen offset
    By mrzigzag in forum Media Engine
    Last Post: 04-10-2004, 04:10 PM
  4. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 08:19 PM
  5. Invertor problem - strange!
    By hasato in forum Software & Software Development
    Last Post: 02-03-2002, 05:55 PM
