Hi!
I have a problem configuring RR to start TV tunner and radio, when i wan't to start TV, nothing happend, but when i wanna start radio, all system "hang up"...
Any advice, what to do? I have TV TUNER ZOLTRIX INT+RADIO.
Printable View
Hi!
-You need to verify this Radio tuner is compatible with Radiator and if so configure it in Radiator OUTSIDE RR propperly (otherwise the radio will not work -- in ANY frontend).
-For TV, you need to setup the winamp TV plugin.
There's a FAQ on Requirements and setup for both of the above, please read them and let me know if you need further help.
Compatible with Radiator??? What does that mean, how to configure this?
OK, i've find Radiator SW, just have to try to configure it correctly, Allso TV plugin...
All that reminded me on another problem... How to configure winamp to produce sound on all 6 outputs from avdio card? I have configured in windows all audio outputs, and thew work correctly, but when i switch to winamp, only 2 outputs are playing sound...
In Winamp prefs, set the DirectSound plugin for Output ...
