Hi there
Ini path can be left blank. It is the position where RR seraches for its config.
The Winamp path is the path where you installed winamp.
Here: c:\programme\winamp <- due to german xp (no winamp.exe behind)
Same as Winamp but the path to your mediaplayer classic but with mplayerc.exe behind.
Start command can be something like: AUDIO or RADIO This will change thescreen towards the thing you entered right after RRs start. shor: if you type radio, the first thing you will see if you start RR is the Radioscreen. You can leave it blank.
Hope you understand my confusing english here. By the way, did you use rrconfig?
THX
Chaos
LinkBack URL
About LinkBacks
