Results 1 to 10 of 17
Thread: Can Someone Clear Up...
    Jaz
    Jaz is offline
    Apr 2005
    How i can search through my playlists?
    i thought that was what the magnifying glass did?
    i sware it worked once, but now i type in a word and it never does anything...
    anyone shed any light?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The search works.. but it starts searching from the CURRENT selection downwards.. If you wish to always search the entire list, you should change the Button code from "SEARCHLIST" to "GOTOFIRST||SEARCHLIST" in audio_player.skin. The Search provided in the folder browser is a file search and it is always for the entire Music folder.
    Ride Runner RR's Myspace
    Jaz
    Jaz is offline
    Apr 2005
    great. will try that later. thanks.
    Jaz
    Jaz is offline
    Apr 2005
    okay it kind of works, at least it goes to the top now.
    what exactly does it seach though? because i search for alot of stuff i know is in my list, but it doesnt go to it...
    FLAC J187's Avatar
    Nov 2004
    Boston
    Give us an example of what your querry looks like and what your file is named.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Jaz
    Jaz is offline
    Apr 2005
    tried all sorts. for example, chemical and searching for galaxy, tried the chemical and also the_chemical
    file name...the_chemical_brothers-galaxy_bounce
    FLAC J187's Avatar
    Nov 2004
    Boston
    OK, not having that song in my directory, I renamed one of my MP3s to be "the_chemical_brothers-galaxy_bounce". I tried the following searches
    "Chemical" = Successful
    "Brothers" = Successful
    "Galaxy" = Successful
    "Chemical Galaxy" = Successful
    So, let me ask you
    1. Are you certain you have the proper directory set in RRConfig file under music?
    2. How did you set the code of your search button? My search button is coded like this: "!BROWSE||SEARCHFILES". It searches my whole music directory for every search
    ps I am using the search files screen.
    Please help.
    Jaz
    Jaz is offline
    Apr 2005
    im using the magnifying glass button. which gives the command that guino to.d me to put in above.
    i will check my RR config but i dont see why it would work now and again if it was wrong.
    FLAC J187's Avatar
    Nov 2004
    Boston
    I am searching my files though, not with searchlist. I am using the searchfiles command. It searches my whole music directory and it is the only thing I'd ever use to find mp3s. I haven't setup any playlists or anything yet.
    Please help.
    Jaz
    Jaz is offline
    Apr 2005
    i still cant get this to work.
    it works the first time after u open it. but after that it wont work again
    ive tried search list, and search files.
    i have so many mp3s, all i want it to do, is when i fancy listening to a particular one i can type in a name, and i can keep searching till i find it.
    like in winamp when you press the . key on the numpad...
    is it right im using the magnifying glass on the main screen or not?
  1. Clear coat.
    By anik321 in forum Fabrication
    Last Post: 06-26-2005, 03:05 PM
  2. Clear plastic window for LED or IR Senesor
    By antimatter in forum General Hardware Discussion
    Last Post: 03-06-2005, 11:32 PM
  3. Replies: 14
    Last Post: 11-10-2004, 08:40 AM
  4. not clear from close up
    By hoodlum in forum LCD/Display
    Last Post: 04-15-2004, 04:33 AM
  5. Please be clear on what you're describing.
    By cproaudio in forum Mp3car Forum Suggestions/Comments
    Last Post: 02-11-2003, 10:42 PM
