Results 1 to 4 of 4
Thread: Help needed for getting info from FreeDrive
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    OK. I'm pretty sure that this has been mentioned before but I cannot seem to find the correct syntax for the following.
    I'm trying to get info from FreeDrive (ETA,ETR,Speed... e.t.c) and place it in a label on any RR skin. This should be automatically updated. Does anyone have the correct syntax for this
    The road is long but we are getting there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tolisn
    You have to edit the configuration in FreeDrive and tell it to send out the labels to RR.. the label codes are basically a set of custom codes that FD updates (CUSTOMFDSPEED, etc).. they're all listed in the same config file.. check this post out:
    Release FreeDrive 0.70 Full
    Ride Runner RR's Myspace
    Nov 2004
    Here is Exactly what you need. I have just done this to the Menu.skin file for the Zots.day skin. It works great. Here is the Information and the attached files needed, including the Image of the LCD showing the Free Drive Information.
    Here is another Menu.skin file that I have made, it removes the Information from the Menu LCD and replaces it with the Information from FreeDrive. The one in a Prior post was for Map Monkey, but I decided there is more information that you can get from FreeDrive, so here it is.
    If you look at the Image, I have removed the Audio Information from the LCD window and replaced it all with the Information From FreeDrive.
    Also, above the On: in the Image is the Next Turn, so if you are to take a Right then above On it will state Turn Right, then On: then below On it will give you the Street Name that you need to turn on.
    The ETR and Time Remaining don't work correctly, but this is a bug in FreeDrive that will be fixed, as stated to me in one of the FreeDrive forum posts.
    Dist to Next: This gives you the data from FreeDrive on how far you have until your Next Turn.
    You need to download the FreeDrive-LCD-menu.skin.zip file. Extract this file to your Zots.day folder under the Skins folder in RR.
    You then Need to download the Freedrive-sdk.ini for Skin to work in RR.zip file and extract the sdk.ini file into your Freedrive Folder, most likely it is located at: C:\Program Files\FreeDrive overwriting your existing file.
    Hope you like this, I am loving it now.
    Bryan
    Attached Files Attached Files
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Dec 2003
    Greece
    Ok Guys, I got the message
  1. Replies: 6
    Last Post: 04-20-2005, 12:26 AM
  2. Logo needed for FreeDrive
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-13-2005, 09:07 PM
  3. clean set up coming up , info needed
    By phase_one in forum Newbie
    Last Post: 01-31-2005, 02:19 PM
  4. General info needed..
    By nehsa in forum Newbie
    Last Post: 09-28-2003, 05:44 AM
  5. VFD info needed.
    By Scrapez in forum LCD/Display
    Last Post: 03-21-2002, 06:24 PM
