Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: RR 07-03-05 .. Fixes ...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 07-03-05 .. Fixes ...
    In this release:
    -Added "RUNQW" dynamic skin command
    -Added work-around for "white border" issue after VIS plugin goes full screen on some video cards
    -Added "ACTIVATE" skin command to directly activate application before sending keys
    -Added Support for the "TUNE" command to tune a XM station using the Numeric OSK
    -Added Support to load images directly into skin (IMG definition)
    -Improved ID3 Genre to support non-numbered/CUSTOM genres
    -Improved overall screen drawing functions to use more API and less VB (faster)
    -Fixed Issue with Radio not resuming at last frequency (Cinergy/WinTV)
    -Fixed Issue with Radio screen freezing up looking for Radiator when not installed
    -Fixed Issue with TAGXXX sometimes not loading when on first song of playlist
    -Fixed focus issues when trying to use the keyboard after clicking on Playlist or Scrolling Label
    -Fixed all the issues with the BackStyle of sliders "flashing" with some skins
    -Fixed Issue with Power Off not working when Exit fuction is set to power off
    -Fixed Issue with FireFox not embbeding when start page is set to "blank"
    -Fixed Issues With MM_Direction indicator (Thanks 307SW_NLD)
    Notes:
    -It may not seem much but I had to do a lot of research and testing to improve the screen drawing functions.. specially to "fix" the white border issue..
    -You will likely have to play with the size/position of the GIF file before it looks decent. This is because the size of the images is not the same so you have to tweak it to your logo...
    -Keep in mind the quality of the loaded images gets worse if you resize them out of proportions -- You should probably resize the image before using it in RR (to prevent distortions). This is the main reason why I've always been reluctant to add such feature.
    -You can load JPG and BMP files with the IMG definition, also, you CAN use transparency in those images by using the color FF00FF (Full Red and Full Blue, no Green -- PINK).
    -Keep in mind JPG compression will likely mess up any color masks you may have done to the image.
    Here are some GIF logos from the Original Brushed skins:
    A-M
    M-Z
    Thanks for your support,
    Guino.
    EDIT: I have updated the image/sliders support to render the images with the same quality as it used to be before this update.. If you downloaded the files before you saw this note, please re-download.
    Ride Runner RR's Myspace
    Nov 2004
    The Install has now been updated with this version.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    sweet thanks! been waiting for this!!!!!!!!!!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Thanks Guino.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Feb 2005
    Quote Originally Posted by bry21317
    Bryan
    is the link from your site? cause on your site, it say latest version was on 6-22-05
    Raw Wave
    Jun 2004
    On the beach
    Cheers Guino, will take a look, thanks for the hard work.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks again Guino...the time between screens is once again even faster...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by Blue ZX3
    Yeah, true!!
    Thanx Guino!!
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Mar 2005
    Balen, Belgium
    Quote Originally Posted by guino
    In this release:
    I was waiting for something like this.
    Thx Guino!
    Oh btw, I just tested it, is it possible to make is so that yo can chose your path? Because now the picture has to stand in the skin folder.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Vipergts/r
    Thx Guino!
    I am very cautious about making anything using full path.. anything skin related is skin-path relative so that you can post it along with the skin and make it work (from different locations) without having to edit any .skin files. Anything that is skin independent has settings in RR's folder pointing to the correct path.. Images loading on skins are very much skin related and should be skin-path relative. You can still point it to a file anywhere in the same drive letter... for instance if the image you need is in:
    And your skin path is:
    C:\Program Files\Road Runner\Skins\BMV2\
    Then you could use something like this:
    IMG,xxx,xxx,xxx,xxx,"..\..\..\..\Images\Image.gif"
    But I stand firm by recommending that you don't do that...
  1. RR 06-21-05 ... Improvements and Fixes..
    By guino in forum Road Runner
    Last Post: 06-28-2005, 11:35 AM
  2. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  3. RR 03-02-05... Fixes only..
    Last Post: 03-07-2005, 01:18 PM
  4. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 12:27 PM
  5. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 01:27 AM
