Results 1 to 7 of 7
Thread: Roadrunner volume
    Jun 2004
    PA
    Roadrunner volume
    No matter what skin I use for roadrunner the volume buttons and sliders don't work. Is it maybe the version of winamp i am using (5.03)?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you have a cheap sound card, you may have to MAP the master volume into an audio line in RRConfig. You can try to control the mixer volumes in the mixer screen.
    Also, make sure that you do NOT have winamp LITE.
    Ride Runner RR's Myspace
    Jun 2004
    PA
    is this considered a cheap sound card?
    I'll check my version of winamp tomorrow.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Shoudn't be a cheap card, although it is likely to give you troble for being USB... in any case, that tells me that you probably have more than one sound card and therefore you have extra steps to make RR work with it: 1-Setup the DEFAULT Sound Card in Control Panel to your SB card. 2-Setup Winamp to use that Sound Card in its options (outside RR)..
    Jun 2004
    PA
    I already set up winamp to use the SB card, but i can't for the life of me figure out how to make the SB card my primary/default card. Do you thinkk you could tell me how to do it step by step or maybe a link that does?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Dude:
    1-Start->Settings->Control Panel
    2-D. Click Sounds and Audio Devices
    3-Click the Audio Tab
    4-Select the PREFERRED sound device on the top of the window
    5-Hit OK.
    Now anything that just tells windows to play/control sounds, will play to/control the PREFERRED sound card unless it's already busy or unavailable.
    Jun 2004
    PA
    when i select the audio tab everything is greyed out and I can't select anything. I'm guessing this is something I removed with nlite and i'm going to try to "repair windows" and see if anything works for me then.
  1. Volume does not work on main screen
    By drewinstl in forum CF Bug Reports
    Last Post: 07-11-2005, 06:53 PM
  2. DVD volume much quieter than mp3 volume
    By bosskong in forum Centrafuse
    Last Post: 02-26-2005, 11:53 PM
  3. Sound Volume Issues
    By ether in forum Media Engine
    Last Post: 08-02-2004, 01:24 PM
  4. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
  5. Replies: 6
    Last Post: 11-12-2003, 10:57 PM
