Results 1 to 5 of 5
Thread: single button toggling two (or more) functions
    Jan 2004
    Champaign, IL
    Is there a way to toggle two functions on a single button? The specific application is for setting mixer presets: one button (on my MENU or GPS screen) which toggles between two presets when pressed.
    Thanks!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    No, unless you intend to load those presets on different functions like XM/RADIO/MP3 (in which case you could load them automatically)..
    I have thought about adding support for toggleling commands on buttons and do intend to add it at some point... right now the best thing you can do is make a small menu to popup and show you two preset buttons....
    Ride Runner RR's Myspace
    Jan 2004
    Champaign, IL
    OK, thanks. I'll sit tight and wait for this sometime in the future. Keep up the awesome work!
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    rjoek,
    I have some toggling buttons in a skin that I’m working on. I did it in flash. They were very easy to make I’m very happy with the results. The only down side is that you can't have them on multiple screens because they could become out of "sync", unless you can communicate between flash movies or receive the preset state from RR somehow.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It should be possible to set and poll the various states of flash movies/buttons/objects/etc by using the custom indicators feature.. You'd set the state of a custom indicator (no need to display it), then you should be able to monitor the state of the indicator using a timer from flash ... this is much like polling labels from RR, just that you get the true/false state of indicators.. this was meant for outside applications but can also be used from Flash..
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 09:15 PM
  2. Hibernation enabled, can't hibernate with Power Button
    By Tercel96 in forum Software & Software Development
    Last Post: 07-20-2005, 02:05 PM
  3. Replies: 2
    Last Post: 04-04-2005, 03:45 PM
  4. button repeating bug?
    By scott_fx in forum Centrafuse
    Last Post: 02-23-2005, 11:35 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
