I'm assuming you're trying to map the same key (say XX key code for instance) to perform different functions in the audio player and on the audio browser... basically you need something like this in KeyTBL.INI:
XX,"PLAY",audio_player.skin
XX,"BROWSE",audio_browser.skin
This will make the same key perform different functions on the screens above... now, there's no way to make the same key perform two different commands in the audio browser (if that was your question)... but you'd need at least a few different commands to be able to fully browse through the folders and select what you want.. UP, DOWN, Browse folder, Go back and Select/Play...
LinkBack URL
About LinkBacks
