Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Timetrax XM and Sirrus USB PC PCR control
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, this is not as simple as the XMD interface to the PC.. the sirius receivers use inverted serial levels which will likely require some type of circuit/interface board on the cable to perform conversion to normal rs232 signaling.. I know there are some poeple that have done that... I also know that it should be possible to use any of the PCR kits, but it is more than likely that they'll have to be opened up to at least look at the appropriate pinouts... if it's hard to find the correct plug for the cable, then it may be necessary to solder the cable/interface onto the sirius box... this really isn't the kind of project that I could simply borrow the hardware and return when done... honestly, I wouldn't even try doing this myself without any help... I do know somebody very good with electronics that could put this together but the best bet would be to talk to somebody who has made such rs232 "adapter/cable" to interface with the PC... I know I can built the software pretty much the same as for the existing XM functionality, but I am not planning on doing any hardware work anytime soon...
    Ride Runner RR's Myspace
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    So we just need to get you one of the PCR units with a RS232 converter. That is a very easy thing to build. I was going to buy one tomorrow to play with anyways. If I can get a TTL to RS-232 converter built and functioning with the unit I will send it your way.
    肚子笑痛了
    S60 Install
  3. #13
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Cool... I can definitely send the unit back after development is completed... I just don't want to be responsible for screwing up a device that I "borrowed" from somebody...
  4. #14
    May 2003
    Miami, FL
    If I can get it working and send it to you, Consider it a donation to the cause
    肚子笑痛了
    S60 Install
  5. #15
    Oct 2003
    Awesome! I might be able to pass along some info that a person who will remain nameless sent my way.
    Also - check out the Sirius Direct units - I think that would be optimal for what we're looking for. It's a no-bull solution - there's no screen or controller, just a raw sirius decoder and control unit. If we can figure out how to pass commands to it, we're golden.
    Dan
  6. #16
    May 2003
    Miami, FL
    Quote Originally Posted by dmurray14
    Dan
    Thats what I was going to go for, I can pick one up at best buy for $50 and I already have all the other parts. So it should be easy to do. Just have to start searching for some pinouts and other information
    肚子笑痛了
    S60 Install
  7. #17
    Oct 2003
    Quote Originally Posted by jcdillin
    Great...that's awesome that you plan on sending it to Guino - I for one appreciate it...it will be nice to have Sirius!
    Dan
  8. #18
    Mar 2005
    TimeTrax already has the Sirius adapters. Wouldn't it just be easier to use one of those? Also, the next version of TT is supposed to be skinable. Very cool!
  9. #19
    Oct 2003
    If they ever get them back in stock, yes the TimeTrax version would be easier. I think people waited like 2 months for the last batch...
  10. #20
    Jul 2005
    I just want to thank you guys for doing this. I've just found this site today and was sad to see no sirius support for rr. It made me even more sad when I saw how good the xm ui looked . Reading this has inspired me to move on with my carputer. PS When you get this up and running how long before it is coded into rr.
