Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Timetrax XM and Sirrus USB PC PCR control
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    The software to control this neat little box that can record off of Satellite radio and the like. The link for the trial version of the software can be found at http://www.timetraxtech.com/tt_download_index.asp This is handy for those who may wish to see if this can be imbedded or added to RR functionality. While the download page says XM a Sirius version is expected to be instock soon
    This little product is the only one so far that will support Sirius to PC connection as well as allowing the use of existing PCR's for sirius
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have all the protocol specs for serius hardware -- I just don't have the hardware.. but it should be fairly simply to add support for it (muxh like the XM support in RR)... I do not intend to make any support for recording/timeshift in RR.. You should be able to embed timetrax in RR and I was under the impression somebody has done that in the past..
    Ride Runner RR's Myspace
    Oct 2003
    Quote Originally Posted by guino
    Can you can you??!? I have been holding off buying Sirius hardware until someone implements it - I would LOVE to see it in road runner!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If I had the hardware and appropriate cable I'd definitely work on it.. also, making the cable can get tricky ..
    Pin/ Wire Color/ Function/ Tuner Module Input/Output
    7/ Blue/ */ Input – 7414 Pin 11
    8/ Purple/ */ Input – 7414 Pin 9
    4/ Orange/ Inverted RX/ Input – 7414 Pin 5
    5/ Yellow/ Inverted TX/ Output – 7414 Pin 4
    6/ Green/ */ Input – 7414 Pin 13
    1/ Black/ + 5v/ Power to UDCU
    2/ Red/ MUTE (Active High)/ Input – 7414 Pin 1
    3/ Brown/ Ground/ Ground to UDCU
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Is there anything you don't know?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DiNASTY
    (Very off-topic)
    Sure... I actually know very little compared to what I don't know (don't we all?)... there's just very little that I woudn't want to know...
    "He who knows his enemies is powerful. He who knows his friends is wise. He who knows himself is enlightened."
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    "He who knows he is rich and flaunts it, is he who knows he is not as happy as he appears to be"
    Off topic but thought I would add the fuel to the fire.
    You can still have something if you have nothing
    Jun 2005
    Jupiter!!!!!! FL.
    Guino
    What precisely do you need. A PCR? there are a few out there depending which head unit you wish to interface to. (Jvc, Pioneer, etc.)
    A din to USB cable?
    Please be more specific what HW you need for your development use.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by accentsound
    Guino
    A din to USB cable?
    That's why I said that getting the cable done can be tricky.. the posted cable pins are for the SC-FM1 (FM tuner based)... but that receiver costs some $170 bucks -- much to high... in theory, we could get any "PCR" type receiver and make a cable for it -- but we'd need to figure out the connection... basically we need:
    -A cable for connection to the PC: Serial or USB -- If USB, I'd need some API/SDK or documentation to talk to it (and may be drivers). This cable should also power the receiver.
    -A Receiver unit that can connect to the cable above and antenna.
    I know the above can be derived from the SC-FM1 but some research would be needed for any other receivers (the cheaper ones). I do know there's some people working on this.. if we could get in touch with them to provide what we need, I'd gladly work on the software portion..
    Jun 2005
    Jupiter!!!!!! FL.
    we have Sirius PCR kits here we have them for JVC and Pioneer. I need to know what you need because we may be able to supply you with a unit for development purposes.
    These units are made to interface with the Bus on Pioneer and JVC Sirius ready head units. and come with a DIN to head unit adaptor cable. I am not referencing those little protable Sirius recievers that use a RF modulator connection to the head unit.
