Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: RR 07-15-05... More improvements..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 07-15-05... More improvements..
    In this version:
    -Added Functional Mode command support (button functions based on fm/xm/mm mode)
    -Added support for Temperature and Voltage readings from same serial port
    -Added Auto-reconnect GPS function (prevention)
    -Added support for switching button commands
    -Added support for controlling volume of any Audio line using buttons and sliders
    -Added support for mute indicators for any Audio line
    -Added INI option to close running embbeded applications upon exit of RR
    -Added Dynamic Equalizer Boost support
    -Improved skin resizing to be of higher quality with anti-aliasing
    -Fixed issue with centering menus when using X/Y skin position
    -Fixed issue with AVS/MilkDrop displacement when using X/Y skin position
    -Fixed issue with clipping screen when using X/Y skin position
    -Fixed issue with slider pointer trail in 7/3 version
    -Fixed fonts on RR/RRConfig to "western" charset
    -Fixed Mute/Unmute Issue with unusual audio input lines
    -Fixed Issue with "negative" memory readings
    -Added dynamic Labels Preview to SkinEditor
    -Fixed Issue with SkinEditor giving errors when "canceling" font/color selection
    -Fixed Issue with "Duplicate" function of skin editor
    -Fixed Issue with SkinEditor adding "skin" to the screen name when saving skin
    -Fixed Issue with SkinEditor's "copy skin" function
    -Changed Skin Editor to display menu.skin automatically when loading a skin
    Notes:
    Some of those fixes have been posted before as a "patch"...
    Look at DynEQ.ini for details on EQ Boost feature.
    Look at Skin commands.txt for new definitions.
    To close embbeded apps when exiting RR add to RR.INI: closeapps=true
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Thanks for the update. Glad to see SkinEditor get a tune-up
    Sounds cool. Lots of improvements in that list that sound very intriguing!
    Jan 2004
    thanks for the update appreciate em.
    Jul 2005
    Newport News, VA
    You da man!
    Athlon XP 1900+, FIC AT31 Radeon IGP320, 256MB PC2100, Toshiba/IBM 7.2K 180GB HD,
    Sony XA-300 USB Audio -> Sony CDA-M600 HU, Integrated TV-Out -> Lilliput 7" Widescreen TV (CRAP),
    Vector 700 Watt Inverter, USB Keypad Control, Windows XP SP2, RoadRunner
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Cool, thanks for the update
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    New York
    Very nice! Guino, any chance we can support launching win32 java files in the upcomming future?
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
    FLAC mauri's Avatar
    Jan 2004
    In this new release I have found 2 small problems:
    1) with the radio D-Link doesn't visualize anymore the writing "stereo" when the station radio transmits stereo.
    2) the volume with the radio D-Link drastically goes down of power in comparison to I listen to some audio player, using the same percentage of settings.
    Tested a will with and without new function of DinEQ, these problems remain.
    In RR config utility I have set the "Master control volume"
    Mauri
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Mauri
    I have not changed anything with the DLink radio for the longest times.. you probably just placed the Dlink folder under RR's directory and that activates the "NEW" DLink driver -- the new driver does not support the stereo indicator NOR the "seek" functions (But it doesn't crash on 2000/XP).. If you wish to restore the old driver, you'll need to copy usbradio.sys from the DLink folder over the one in your windows\system32 folder, then rename or delete the dlink folder.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DaRacerz
    You can probably do this by running "java <appname>" or whatever -- you'll probably need to include the full path of java.exe and for the application.. I've done this from VB before.. it might be easier to run a .BAT file with all the pathnames and parameters correctly (since java is a ***** when it comes to requiring parameters for libraries and such)...
  1. RR 06-21-05 ... Improvements and Fixes..
    By guino in forum Road Runner
    Last Post: 06-28-2005, 11:35 AM
  2. RR 05-06-05 ... Improvements ...
    Last Post: 05-12-2005, 11:10 AM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR 04-02-05 ... Few improvements..
    Last Post: 04-05-2005, 09:34 PM
  5. RR 03-07-05.. Few Improvements..
    Last Post: 03-07-2005, 06:44 PM
