Results 1 to 4 of 4
Thread: How to get RR to run on a second (external) monitor?
    May 2005
    Vienna, VA
    Forgive me if I missed this somewhere in the threads here.
    I'm using a laptop and want to run RR on my second (external) monitor. How do I do this? Looks like RR locks to (0,0).
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    open general.ini on your skin's folder, change the X/Y position as desired.
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    Thanks, guino. That works. Now the problem is video/DVD doesn't display on the external monitor. I know that this is just a video overlay problem. Is there any workaround for this?
    Thanks again.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that will depend exlusively of the software/hardware used... there's typically a setting to select the output monitor... maybe the easiest thing is to put RR in the 1st screen, swap the cables and move the monitor 2 to the left of monitor 1 in the display propperties... this should virtually be the same as the initial setup...
  1. Auto load FD when RR starts up
    By tolisn in forum Road Runner
    Last Post: 07-08-2005, 05:30 PM
  2. Help with External GPS on RR
    By Pabs in forum Road Runner
    Last Post: 06-18-2005, 12:22 AM
  3. 15" Monitor location
    By mikemerrill50 in forum Fabrication
    Last Post: 05-02-2005, 09:53 AM
  4. Requirements to run RR properly
    By oekundar in forum Road Runner
    Last Post: 03-07-2005, 07:40 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
