Results 1 to 10 of 20
Thread: horm and RR playlist resumes thoughts
    Mar 2003
    UK
    If you have Horm setup for your hibernation every time you load up the hibernation file is resumes from the same song all the time as it goes back to the setting used for the original hibernation file
    Now if there was a text file with the last song played and what setting you had for the music playing that is written to every time a song played so when you come out of “Horm” hibernation all RR would have to do would be to read that file to know where it was before."this file could be on mem stick or what ever drive you like"
    Would that work for resuming the music from where you left off on a Horm setup?
    Just a thought
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Search for horm support.. this is already implemented.. before hibernation RR saves the playlist, song number and position (time) , upon resume, it reads and restores everything.. you just need to add an INI line to make that happen..
    Ride Runner RR's Myspace
    Newbie Grazor's Avatar
    Nov 2004
    Winchester, England
    M Pro,
    Are you going to JAE this weekend??? I'd really like to have a peek at your CarPC if you are.
    1999 Nissan 200SX
    Epia M9000 + 7" Lilliput
    Follow my CarPC Install
    Nissan 200SX Owners Club
    Sep 2003
    LA, CA
    Quote Originally Posted by guino
    Guino...
    i just got horm working...
    and i did search but what is INI line to make it happen?
    i see 'ini path' in RRConfig but it just saves RR.ini in certain path
    then i don't think rr read it from the path given...
    do i have to install RR in writable partition?
    or can i save resume.ini in different drive?
    thank you...
    Feb 2005
    I was the one that originally requested this and guino add support but I never fully got it working correctly. I had RR on a writable partition and the ini command was
    hibernatereload=true
    You have to manually add that to the ini, and if you run the config program after you add it, you have to go back and add it again...
    Let me know if you get it working right. I ended up disabling EWF and doing a cold boot everytime because of the random errors I was getting with files and such on my writable partition.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The INI is RR.INI in RR's path in case you wonder.. I know there's a few people using this currently.
    Sep 2003
    LA, CA
    Quote Originally Posted by CornFlake340
    i read the intruction for ewf and horm
    and according to it, it is recommended not to connect any other writable partition when making save point...
    it may cause random error...
    so i think we should keep RR installed in protected partirtion...
    and save only resume.ini in writable partition...
    guino
    what is point of 'ini path' in RRConfig?
    i think RR should save resume.ini in independent path...
    and just wondering...
    does RR save info into 'resume.ini' before hibernating? or shutting down?
    because there no point to save info before go into hibernation...
    once making saving point for HORM, windows just shuts down and i think that is the point where RR should save 'resume.ini'
    i don't know if it is the way RR works now...
    thank you...
    Sep 2003
    LA, CA
    guino
    now playlist_path will be "/" if it is empty
    bewfore it gets to the line [ if playlist_path = "" then playlist_path = music_path ]
    Case "inipath"
    INI_PATH = Trim(dt(1))
    If INI_PATH <> "" And Right(INI_PATH, 1) <> "\" Then INI_PATH = INI_PATH + "\"
    Case "playlistpath"
    PLAYLIST_PATH = Trim(dt(1))
    If PLAYLIST_PATH <> "" And Right(PLAYLIST_PATH, 1) <> "\" Then PLAYLIST_PATH = PLAYLIST_PATH + "\"
    Case "lazytag"
    also i added INI_PATH where save 'resume.ini' into...
    and change all myPath + "resume.ini" to INI_PATH + "resume.ini"
    and also if i change all winamp_path + "winamp. m3u" to PLA YLIST _PATH + "winamp.m3u", RR will save playlist on exit to playlist_path...
    this way HORM resume with all info updated each time...
    i will compile these and try on my car and let you know...
    Feb 2005
    So where do you save your media files? On the un-writable partition? Or a seperate drive that you would disconnect before making save point, and then turn off, re-connect... turn on... ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I am not sure I understand what's going on.. The INI path setting in RRConfig wasn't my idea but it is usefull in case you intend to run it to configure RR on a different location/computer.
    Playlist path is intended to default at RR's folder.
    The resume.ini is saved/reloaded when hibernating, exiting, powering off etc..
    I recommend using RR from a writeable partition simply because there are many INIs used and they're all saved in RR's path. Also you may want to add/remove different skin (I know that can be separated -- it is just more organized inside RR's folder). Also anytime there's an update many files change and you'll have to burn your flash card again or whatever.. It should not affect the performance of RR and should be easier on you to update it.
  1. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 01:47 AM
