Results 1 to 4 of 4
Thread: Auto Detach - Reattach MM on Skin change
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Question Auto Detach - Reattach MM on Skin change
    Hi Everyone. Actually when I change the RR skin MapMonkey closes. Just wondering if was possible avoid re-open MapMonkey every time i change skin.
    Needed to add some commands on select skin button or what
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is a design limitation.. you can add something like this to ExecTBL.INI to relaunch it automatically:
    "SELECT","NEWSKIN",skin_browser.skin
    "NEWSKIN","SELECT||DESTINATOR||MAIN",MM
    "NEWSKIN","SELECT"
    The above will detect the select button on the skin browser, and if MM is running, it will re-launch MM upon changing the skin then exit back to the main menu (this will take a few seconds likely).. and if MM is not running it will not auto start it.. I have not tried the above but it should work..
    Ride Runner RR's Myspace
    Feb 2005
    Italy
    Guino, i've read your ToDo list, and there is the Auto Day/Night Gamma/Skin. This means that on the skin autoswitch RR will produce the same result on MM or FD if these are running?
    Thanks for the reply
    Fabio
    Travla C134
    Feb 2005
    Italy
    Quote Originally Posted by guino
    "NEWSKIN","SELECT"
    Guino, i've tested the commands above but without success. RR Stops to responds pressing any button before i can enter in the skin browser. Any idea?
    Fabio
    Travla C134
  1. Auto Time-Out to Default Skin Screen?
    By timwiththebo in forum Road Runner
    Last Post: 07-02-2005, 01:28 AM
  2. Night skin AND Gamma
    By cdevelasco in forum Road Runner
    Last Post: 05-16-2005, 01:36 PM
  3. auto display cover art on change
    By freestyler in forum FrodoPlayer
    Last Post: 10-27-2004, 01:58 PM
  4. how do i change the skin
    By deathduck in forum FrodoPlayer
    Last Post: 09-08-2004, 11:09 AM
  5. Auto skin switching by lights
    By craigyb in forum FrodoPlayer
    Last Post: 07-12-2004, 12:11 PM
