Results 1 to 5 of 5
Thread: Multiple command
    Feb 2005
    Multiple command
    hey Guino, I tried the double pipe to input 2 command but it doesn't work, in the Zots audio skin, when I hit select all, it select all but doesn't play
    here's what it is:
    B01,5,299,68,73,"SELECT+","Select"
    I used the double pipe and did this
    B01,5,299,68,73,"SELECT+||PLAY","Select"
    but now it won't even select, how do I make it work?
    also, I am trying to congifure girder, let say I want to assign a button to increase the bass by 1, how do I input the command?
    I have tried this but no luck
    "BASS||UP"
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I am unsure of what you're trying to accomplish with "SELECT+||PLAY".. if you want to load the listed songs to playlist and automatically play the selected song, you should use "SELECT" (without +)... if you want to ADD the listed songs to the playlist you should use "SELECT+" ... select+ will not automatically play anything. The double commands work, but some commands that heavily relate to winamp control typically fail to respond if put in sequence...
    I can probably add commands to perform bass/treble level changes... something like: "VOL+;BASS" or "VOL-;TREBLE"...
    Ride Runner RR's Myspace
    Feb 2005
    cool thanks, I thought select+ was something esle, was confused oh, and one more problem
    I have power dvd as for dvd player, it load up and everything, but the small powerdvd control panel doesn't dissappear ever. I have try to go into it's configuration but still no luck. any help on this?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I use PowerDVD in the car myself.. it works fine.. the window will not go away if you move the mouse (even if just 1 pixel every so often) or if you press keys (every so often)... If you have a mouse in the car for instance this could be the cause.. otherwise as long as you have the Video Auto-hide option set in RRConfig it should work..
    Feb 2005
    I did have the Video Auto-hide checked, and I am testing it on my desktop, still, the "powerdvd" control panel will not disappear nor move. I tried to move it, but then it would jump back to that position. I don't think it's the skin problem, because I am using the Zots skin, and switch to BAV2 skins, but still same problem. I am using powerdvd v.6, which version are you using?
  1. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-22-2006, 11:12 PM
  2. Replies: 4
    Last Post: 07-06-2005, 01:07 PM
  3. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 05:19 PM
  4. Multiple Monitors and Multiple inputs
    By nixneon in forum Newbie
    Last Post: 03-19-2005, 07:30 PM
  5. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 10:53 PM
