Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: SKINbedder embedding problem
  1. #11
    was Boston -> now Canada!
    OK I appear to be having major issue with the Delorme USB to Serial drivers. THey work when they want to work it appears.
    I just did an uninstall of the drivers with the receiver disconnected, then connected the received and reinstalled the drivers. RR now embeds correctly.
    Why does the embedding not work when a receiver is not detected? Seems strange to me but maybe there is a logical explaination.
    Anyone have any better drivers for this Earthmate or should I just trash this darn thing? I imagine any USB receiver I get will need the USB to serial drivers so it probably will not make sense to just get a different one.
    Chuck
  2. #12
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I've played a little with Skinbedder in existing skins but now I'm making my own and I'd like some clarification on what can be done directly in RR vs SB to display/customize IGuidance. I understand SB allows you to create buttons to control IGuidance (&others) but can't RR do the same directly? If so, I'd like to avoid the bloat of adding additional apps (SB and AutoIt) and avoid the confusion of having to use two skinners.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can't REPLACE the buttons in IG with RR... and if you want to send commands to IG you'll have to have to make special buttons for EACH skin you use.. SB allows you to use the same buttons etc in different applications and skins.. Plus SB has a few improvements on NAG removals etc..
    Ride Runner RR's Myspace
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 08:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 08:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  5. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
